Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Automatic crossover designing with XMachina
Old 14th January 2018, 05:37 AM   #11
diyaudnut is online now diyaudnut  United States
Very interesting Xmech! Thanks.
Old 9th February 2018, 08:18 PM   #12
XMechanik is offline XMechanik  Poland
New version of XMachina: [1180209].
An option to digitize impedance characteristics in logarithmic scale has been added to the axis definition window. (For example Scan-Speak data datasheets use logarithmic impedance charts).
Few simple tools have been implemented in the measurement simulator, supporting to estimate characteristics outside the loaded range.
The characteristics can be “tailed” with a specified slope or extrapolated with a slope calculated from the characteristic shape at the edge. In case of impedance characteristics, values of DC resistance (Re) and voice coil inductance (Le) can be utilized for the estimation (Re for low and Le for high frequency range).
Estimation improves the accuracy of phase calculation. It was used also in the previous version but only as an “on the fly” action during the acceptance of measurements simulator results.
Old 11th February 2018, 01:43 PM   #13
prakashbytari is offline prakashbytari  India
Hi... i have downloaded the link and pdf doc. can i get the pdf in english version.
Old 11th February 2018, 07:48 PM   #14
Open the page xmachina-ai.blogspot.com and then:
1) click the "Documents" tab,
2) click on the link next to the "(EN)" to download pdf.
This pdf should be in English (that was at least my intention ).
Old 19th April 2018, 10:07 PM   #15
Few improvements and corrections in the new version [1180415]:
  • Measurements simulator: front baffle characteristic is applied also on the LF response.
  • “Recent" submenu was added in the "File" menu for easy re-opening previous works and experiments.
  • Circuit price calculation: when moving mouse over a design node, the price appears in the status bar. This works only if all of the elements included in the circuit have price defined (check your components lists), otherwise it is displayed as "n/a". Remember to use the same currency for all elements when creating lists of components for a design.
Price calculation feature made me think of an idea to include circuit price reduction as an additional (optional) goal for the automatic designer. Maybe it will appear in one of the next versions
XMachina page thread
Old 8th May 2018, 10:01 PM   #16
Mosquito is offline Mosquito  Argentina
Mosquito's Avatar
Default ???
I was trying Xmachina, a two way xover, using actually measured frd and zma files (Klipsch K24K woofer, Visaton TW70 tweeter). I set the constraints to medium accuracy, 90dB spl target, 400 to 7000Hz range optimization.
Program give three solutions, I liked the second one, but, but.. I have no clue on how to interpret the proposed filter schematic... any idea?
"It is less serious than if worst"
Old 9th May 2018, 09:50 PM   #17
It's just that:
Automatic crossover designing with XMachina-a01-png
Maybe one remark here, in the task setup windows the first Way is named "Woofer" and the Way with the highest index is named "Tweeter". It looks that it is swapped in your design but there is nothing wrong with this as it is only a naming convention.
After grounding the amp's black connector and inverting polarity of both speakers, the designed crossover appears like this:
Automatic crossover designing with XMachina-a02-png
One more comment, it's about the "Design frequency band" in the task setup window. It defines the focus frequency range for XMachina. In other words, XMachina assumes that it's not importatnt what's going on outside, which may lead to undesirable effects if the range is set too narrow.
If the intention is to optimise (shape) characteristic in a region but also make filters "transparent" outside, just let the target spl follow the drivers characteristics outside, keeping the "Design frequency band" wide enough.
To clarify, I attach a screenshot from XMachina doc as an example (chapter "Target dBspl setting", target characteristic is marked green, woofer is red, tweeter blue):
Automatic crossover designing with XMachina-a04-png
Old 9th May 2018, 11:41 PM   #18
Mosquito's Avatar
Thanks, I can see it, my error was setting the optimization band too narrow, not understanding the logic of the program.
Nevertheless, I persisted and now this thing is throwing good data, a truly fantastic tool, once You learn how to use it..
Double checking the filters on Xsim is a very good idea too.
Again many thanks for sharing this amazing tool
Old 11th May 2018, 09:27 PM   #19
Mosquito's Avatar
once you get it running is nothing short than..amazing!
Automatic crossover designing with XMachinaHide this!Advertise here!
Need help designing a crossover djn Multi-Way 10 24th January 2015 11:43 PM
Why Only Automatic/Semi-Automatic Bias? PsychedelicFish Tubes / Valves 4 26th October 2013 10:07 AM
Designing a crossover oldbar Multi-Way 2 2nd February 2009 11:48 PM
ACS- Automatic Crossover Shift (SQPL possible?) Bad silver Car Audio 3 13th March 2007 08:03 AM
Need help designing crossover soundNERD Chip Amps 27 7th December 2003 02:08 AM
