Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Speaker Crossover Simulation Software
Old 10th December 2017, 08:21 PM   #21
88man is offline 88man  United States
Originally Posted by kimmosto View Post
It's quite new software in this scene, freeware since 2016-09-11. Some users might prefer free form X/O schema and solver which are not (yet) included, but fortunately many other valuable features are already done. Author's (my) needs were met half a year ago, but project seems to continue. Nelder-Mead simplex solver is already added in the source package. One day we might see some way+axial+power+impedance optimizing mammoth... - or not
Bravo! This looks like an amazing tool that combines several tasks under one roof. I need to figure out how to go about starting out. I've done box modeling, but that's about it in terms of softtware simulation. I haven't done any tracing of graphs, curves, or importing, exporting, or merging any data files. I'd also like to add new drivers, namely the Scan-Speak 18M/8631T, SBA MW16P-8 SBA TW29BN, SBA WO24P-8.
Old 11th December 2017, 04:16 AM   #22
kimmosto is offline kimmosto  Finland
Design process is listed in section Checklist for designing a loudspeaker, starting on page 4 in user manual. See also youtube lessons and document Measurement preparations: recommended angle step for polar measurements is 10 deg. Horizontal plane only is usually adequate. Measurement gear should be 2-channel, for example ARTA 1.9.1, Sonarworks XREF20 and Focusrite Scarlett Solo. I've not tested Solo and XREF, but should be okay. Just forget Omnimic, Umik-1 and REW, though these are very popular for measuring room acoustics.
Old 11th December 2017, 04:33 AM   #23
LineSource is offline LineSource  United States
LineSource's Avatar
I'm planning to place the 22W/8851T00 in a 40L ported cabinet to make a smaller footprint than 55L. I thought I can make this speaker with 11in wide top and bottom cabinets.
The 8" Scan-Speak 22W/8851T00 in a 44L volume appears to perform best (-F3=33Hz) with a port tuned to 31Hz for a modest bass shelf alignment with just ~0.8db droop between 200Hz and 45Hz, then dropping to (-F3=33Hz) .
(31Hz port: Diameter = 3", Length=10.5", both ends rounded)
The 8" 22W/8851T00 has cone area Sd= 220cm2
The 10" SB29NRX75-6 has cone area Sd= 312cm2
So, with a passive crossover the excellent 22W/8851T00 will produce solid bass, but not the same impact at <40Hz as the SB29NRX75.
The Satori MW16P-8 needs a sealed 13.5L for QB3 0.7 alignment with -F3=67Hz ... not tiny. The Kairos box is 17L before adding speakers.
Old 12th December 2017, 02:21 AM   #24
kimmosto, thank you for the great launch of tutorials and preparation needed to get started. Your program is an elegant approach encompassing so many aspects of modeling, and loudspeaker design principles, all under one roof.
LineSource, thanks for the in depth analysis of the 22W/8851T00 driver for the SBA 10 kit. It's encouraging to know that the 8" driver will be only -0.8dB from 45-200Hz. 44L is definitely doable, as I've done a 43L cabinet for my Scan-Speak "Classic" 8-7-1 speakers. The "Classic" drivers are 20 years old, I think the new drivers will provide increased transparency, dynamics, and lower compression.
Speaker Crossover Simulation SoftwareHide this!Advertise here!
SpeakerSim speaker simulation software LightBit Software Tools 54 13th August 2018 10:23 AM
speaker simulation software for Mac OSX rebojorge Multi-Way 24 17th January 2016 08:07 PM
Does crossover auto simulation software? doug20 Multi-Way 24 9th March 2010 03:41 AM
Speaker measurement and simulation software? Few Multi-Way 8 4th June 2004 08:31 AM
Software speaker simulation weirdness jteef Multi-Way 6 12th January 2002 08:59 AM
