Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Speaker Crossover Simulation Software
Old 10th December 2017, 03:01 AM   #11
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Tracing includes zero box / baffle effects, and of course, may not be related to your actual drivers. Lots more prone to error and a lot more work I think.
Far better to measure the parts you got, and the box you built.
Best,
E
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 10th December 2017, 06:08 AM   #12
LineSource is offline LineSource  United States
LineSource's Avatar
Originally Posted by 88man View Post
What I'm trying to do is to make a 200Hz, 2nd order, low pass section using the Scan-Speak 22W/8851T00 driver and substitute it into Troel's SBA 10 3-way speakers.
At 200Hz in a 55 Liter ported cabinet, the 8" Scan-Speak 22W/8851T00 produces about 2db lower SPL than the 10" SB29NRX75-6. Probably acceptable if the speaker is close to a wall.
LR2 circuit at 200Hz for Scan-Speak 22W/8851T00 uses 12mH iron core inductor with low DCR, and 50uF capacitor. You can experiment with an LRC notch filter to flatten the 58 ohm resonance peak impedance at 30Hz. Note that the modest bass shelf port is tuned to 28Hz, and this will complicate the notch filter design.
Scan-Speak 22W/8851T00 in a 55-liter volume tuned to 28Hz for a modest bass shelf alignment requires a 3" vent (round both ends) 10.5" long
VituixCAD, The Loudspeaker Simulation Tool by Kimmo Saunisto
If you plan on making turn-table polar measurements, VituixCAD is set up to integrate this data into a complete simulation: driver database, enclosure, diffraction, crossover, polar plots.
There is a free download version.
Old 10th December 2017, 06:23 AM   #13
AllenB is offline AllenB  Australia
Wrong. I trace from measured data from other programs.
Old 10th December 2017, 07:39 AM   #14
fatmarley is offline fatmarley  England
How do you work out the relative acoustic centres with tracing?
Old 10th December 2017, 08:10 AM   #15
Zvu is offline Zvu  Serbia
Zvu's Avatar
Originally Posted by AllenB View Post
The limitation I don't like with most crossover simulators is that they are stuck in 2D.
In what way ?
If you're referring to showing only what happens on one axis, VituixCAD solves that problem. Kimmo Saunisto did tremendous job and it's all free.
Software
Not for fainthearted
Old 10th December 2017, 08:23 AM   #16
OK. Speaker Workshop is open plan and and you can do various plot transformations. To me this is about finding the right plots to use before crossing which is important enough. It also allows EQ adjustments and so forth. There is also the not so well known 'xo', which will show polar plots while crossing, which is nice although perhaps not strictly necessary.
Old 10th December 2017, 11:57 AM   #17
Pano is online now Pano  United States
Pano's Avatar
VituixCAD is a software that gets rare mention on this forum. I forgot all about it. Don't know why it isn't used more, it's amazingly complete.
Take the Speaker Voltage Test!
Old 10th December 2017, 12:59 PM   #18
Zvu's Avatar
It's better than LspCAD that i use and it's free.
I'm a member on few forums that almost exclusively use Vituix.
Old 10th December 2017, 01:37 PM   #19
88man is offline 88man  United States
Many Thanks, Linesource, for the calculation! I'm planning to place the 22W/8851T00 in a 40L ported cabinet to make a smaller footprint than 55L. Since I already have the 22W, mid, and Be tweeter, I thought I can make this speaker with 11in wide top and bottom cabinets.
VituixCAD looks amazing, both electronically and acoustically! It has a Diffraction Simulator, which will be very useful to calculate baffle step compensation, loss, nasties in FR. I'm going to look into this more carefully. Just wow!
Thank you Zvu, Pano, AllenB, fatmarly, Eriksquires, and Linesource for all chiming in with great ideas!
Old 10th December 2017, 04:07 PM   #20
kimmosto is offline kimmosto  Finland
It's quite new software in this scene, freeware since 2016-09-11. Some users might prefer free form X/O schema and solver which are not (yet) included, but fortunately many other valuable features are already done. Author's (my) needs were met half a year ago, but project seems to continue. Nelder-Mead simplex solver is already added in the source package. One day we might see some way+axial+power+impedance optimizing mammoth... - or not
Speaker Crossover Simulation SoftwareHide this!Advertise here!
SpeakerSim speaker simulation software LightBit Software Tools 41 18th June 2018 06:51 PM
speaker simulation software for Mac OSX rebojorge Multi-Way 24 17th January 2016 08:07 PM
Does crossover auto simulation software? doug20 Multi-Way 24 9th March 2010 03:41 AM
Speaker measurement and simulation software? Few Multi-Way 8 4th June 2004 08:31 AM
Software speaker simulation weirdness jteef Multi-Way 6 12th January 2002 08:59 AM
