Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
SpeakerSim speaker simulation software
Old 24th December 2017, 07:58 PM   #31
LightBit is offline LightBit  Slovenia
LightBit's Avatar
Originally Posted by Boden View Post
Does this software work with target curves and does it have an optimizer?
No target curves and no optimizer.
Is the active filter circuitry freely configurable or does it consist of pre defined filter blocks?
No, it is just pre-defined high level without any circuits (you define frequency, Q, and dB).
Old 6th June 2018, 07:01 PM   #32
LightBit's Avatar
New version 2018-06-06:
  • Room simulation improved
    • All 6 first reflections simulated
  • Smoothing
  • Chart rendering library updated
  • Bug-fixes
Windows setup (.exe)
Windows portable (.zip)
Other (.jar)
Old 6th June 2018, 11:19 PM   #33
Tromperie is offline Tromperie  Australia
I just ran the Windows insaller package, set the environment altitude as 3 metres and got this error message;
java.lang.NullPointerException
SpeakerSim.PowerResponseSimulation.<init>(Unknown Source)
SpeakerSim.BassReflexSimulation.<init>(Unknown Source)
SpeakerSim.Speaker.refresh(Unknown Source)
SpeakerSim.Item.childrenRefresh(Unknown Source)
SpeakerSim.Item.refresh(Unknown Source)
SpeakerSim.PassFilter.refresh(Unknown Source)
SpeakerSim.GUI.MainWindow.refresh(Unknown Source)
SpeakerSim.GUI.MainWindow.menuEnvironmentActionPer formed(Unknown Source)
SpeakerSim.GUI.MainWindow.access$1400(Unknown Source)
SpeakerSim.GUI.MainWindow$41.actionPerformed(Unkno wn Source)
javax.swing.AbstractButton.fireActionPerformed(Unk nown Source)
javax.swing.AbstractButton$Handler.actionPerformed (Unknown Source)
javax.swing.DefaultButtonModel.fireActionPerformed (Unknown Source)
javax.swing.DefaultButtonModel.setPressed(Unknown Source)
javax.swing.AbstractButton.doClick(Unknown Source)
javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unk nown Source)
javax.swing.plaf.basic.BasicMenuItemUI$Handler.mou seReleased(Unknown Source)
java.awt.Component.processMouseEvent(Unknown Source)
javax.swing.JComponent.processMouseEvent(Unknown Source)
java.awt.Component.processEvent(Unknown Source)
java.awt.Container.processEvent(Unknown Source)
java.awt.Component.dispatchEventImpl(Unknown Source)
java.awt.Container.dispatchEventImpl(Unknown Source)
java.awt.Component.dispatchEvent(Unknown Source)
java.awt.LightweightDispatcher.retargetMouseEvent( Unknown Source)
java.awt.LightweightDispatcher.processMouseEvent(U nknown Source)
java.awt.LightweightDispatcher.dispatchEvent(Unkno wn Source)
java.awt.Window.dispatchEventImpl(Unknown Source)
java.awt.EventQueue.dispatchEventImpl(Unknown Source)
java.awt.EventQueue.access$500(Unknown Source)
java.awt.EventQueue$3.run(Unknown Source)
java.security.AccessController.doPrivileged(Native Method)
java.security.ProtectionDomain$JavaSecurityAccessI mpl.doIntersectionPrivilege(Unknown Source)
java.awt.EventQueue$4.run(Unknown Source)
java.awt.EventQueue.dispatchEvent(Unknown Source)
java.awt.EventDispatchThread.pumpOneEventForFilter s(Unknown Source)
java.awt.EventDispatchThread.pumpEventsForFilter(U nknown Source)
java.awt.EventDispatchThread.pumpEventsForHierarch y(Unknown Source)
java.awt.EventDispatchThread.pumpEvents(Unknown Source)
java.awt.EventDispatchThread.run(Unknown Source)
Source: Daphile on old PC from the tip * Storage NAS: FreeNAS 11 * Pre-amp: DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3,000Hz * Speakers: DIY design CNC cut 54 laminations * Drivers SB 10", SB 5", VIFA 1" VTG
Old 7th June 2018, 04:31 PM   #34
LightBit's Avatar
I cannot reproduce this.
You probably did something before that. Can you reproduce it?
If you can really reproduce it by only setting altitude to 3, try with debug build which shows more info on error and paste it again.
Old 8th June 2018, 01:16 AM   #35
I didn't change anything else before changing the altitude. I tried it again and it didn't happen.
Old 10th June 2018, 01:39 PM   #36
keantoken is offline keantoken  United States
keantoken's Avatar
How would you suggest to model an aperiodic enclosure?
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 10th June 2018, 05:27 PM   #37
LightBit's Avatar
I would simulate it as Bass Reflex with stuffed port (low Qp and probably also low Qa).
I would also use port calculator for vent dimensions (or for number of Variovents).
To make it typical aperiodic enclosure set frequency to frequency of closed box at that volume. Simulation will show you typical aperiodic low impedance at resonance.
Old 12th June 2018, 07:18 PM   #38
LightBit's Avatar
New version 2018-06-12:
  • Aperiodic simulator
  • Open Baffle simulator (needs a lot of testing)
  • Prevent tree item deselection
  • Other small bug fixes
  • Better error messages
Other (.jar)
Old 13th June 2018, 07:51 PM   #39
LightBit's Avatar
New version 2018-06-13:
  • Open Baffle simulator fixed
    • I did quick comparison to MJK open baffle designs and it is much closer now
  • Faster start (removed unnecessary refresh)
Other (.jar)
Old 16th June 2018, 02:41 PM   #40
LightBit's Avatar
New version 2018-06-16:
  • Interface now stays responsive while doing simulation (also possibly introduces new bugs )
Other (.jar)
SpeakerSim speaker simulation softwareHide this!Advertise here!
speaker simulation software for Mac OSX rebojorge Multi-Way 24 17th January 2016 08:07 PM
simulation software hacknet Tubes / Valves 6 15th December 2005 02:11 PM
Speaker measurement and simulation software? Few Multi-Way 8 4th June 2004 08:31 AM
Software speaker simulation weirdness jteef Multi-Way 6 12th January 2002 08:59 AM
