Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
SpeakerSim speaker simulation software
Old 28th November 2017, 05:35 PM   #21
LightBit is offline LightBit  Slovenia
LightBit's Avatar
New version 2017-11-28:
  • New default positions for new projects (speaker and listening position used to be the same)
Old 3rd December 2017, 06:42 PM   #22
LightBit's Avatar
New version 2017-12-03:
  • New power handling simulation:
    • IEC 268-5 power is shown instead of linear power
    • "Pe defined at" parameter added to driver for tweeters (when power is defined with high pass filter)
  • Excursion simulated with IEC 268-5 filter
IEC 268-5 filter:
  • low pass 3dB filter at 0Hz
  • low pass 12dB filter at 5kHz
  • high pass 12dB filter at 40Hz
Old 12th December 2017, 07:28 PM   #23
LightBit's Avatar
New version 2017-12-12:
  • Windows setup and Windows portable (with JRE)
  • Icon
Windows setup (.exe)
Windows portable (.zip)
Other (.jar)
Old 16th December 2017, 09:14 AM   #24
LightBit's Avatar
I have repacked Windows portable with OpenJDK instead of Oracle Java. It is also slightly smaller now.
Old 17th December 2017, 11:58 AM   #25
Xpandsound is offline Xpandsound
Trying to install this on windows 7 and it fails ? Cannot find main GUI ?
Old 17th December 2017, 01:57 PM   #26
LightBit's Avatar
Thank you for reporting. I have tested it on Windows 7 (32 bit) without Java installed and it worked.
Please answer this questions to help me determine where the bug is:
  • Did you have Java installed?
  • If you have Java installed which version?
  • Did SpeakerSim try to install Java?
  • 32 or 64 bit Windows?
  • Does SpeakerSim.jar work?
  • Does portable (zipped) SpeakerSim work?
Old 17th December 2017, 07:34 PM   #27
LightBit's Avatar
New version 2017-12-17:
  • Listening window response graph
  • Power response graph
  • Directivity graph
  • Excursion bug introduced with previous version fixed (it showed excursion at 1W)
  • Java version check fix (possibly Xpandsound's problem)
  • All files are smaller
Download:
Other (.jar)
Old 18th December 2017, 09:47 AM   #28
It's ok I downloaded the pack you provided and everything works fine now. I previously only used the win installer (.exe) Going to try this
Old 18th December 2017, 07:15 PM   #29
LightBit's Avatar
New version 2017-12-18:
  • Move left bug fixed
Other (.jar)
Old 24th December 2017, 07:07 PM   #30
Boden is offline Boden  Netherlands
Hello LightBit,
Does this software work with target curves and does it have an optimizer?
Is the active filter circuitry freely configurable or does it consist of pre defined filter blocks?
Thanks,
Eelco
SpeakerSim speaker simulation softwareHide this!Advertise here!
speaker simulation software for Mac OSX rebojorge Multi-Way 24 17th January 2016 08:07 PM
simulation software hacknet Tubes / Valves 6 15th December 2005 02:11 PM
Speaker measurement and simulation software? Few Multi-Way 8 4th June 2004 08:31 AM
Software speaker simulation weirdness jteef Multi-Way 6 12th January 2002 08:59 AM
