Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
SpeakerSim speaker simulation software
Old 12th November 2017, 12:46 AM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I haven’t tried any modelin yet, but the ap does launch and, as much as i poked around, runs fine under Mac OS X 10.12.6.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th November 2017, 12:52 AM   #12
tcpip is offline tcpip  India
Originally Posted by LightBit View Post
I wrote it in Java, because it is practically the only language where you can write program with GUI anywhere and run it anywhere.
I think Java is a great choice. And I don't believe there is any security challenge for a standalone application written in any of the modern languages, since you're not opening network ports or communicating with data which you are downloading. What security holes then remain will be almost entirely language independent.
If I were in your place, I'd probably not even say which programming language it's written in. I'd just create a nice Windows installer which would download and install the JRE automatically if it was missing, before installing your JAR file. And it would create a desktop icon for launching. That way, many users wouldn't even ask what language you've written it in.
Will your application now have the distinction of being the first speaker design software written from Day 1 to be open source? Other than Charlie Laub's Active XO Designer, I guess. I know that Speaker Workshop later was released in open source but was not that way from its birth. Several years ago, a lady from one of the Scandinavian countries had put up a website talking about an open source speaker design application she was writing. I don't think it got completed. I can't find the web page now. UPDATE: I just discovered there is something called GSpeaker... though it's a dead project. Last news is from 2004?
I'm a Linux user. I've been trying to do speaker design without booting Windows for 12 years now, and of course, there's very little I can do in Linux. Some spreadsheets work in LibreOffice, that's about it. Even the old faithful Unibox, which claims it works in OpenOffice, actually doesn't work properly in LibreOffice today. I've recently switched from Eagle PCB design software (on Linux) to KiCAD and am still struggling to learn it. Your application will be a thrilling step forward for me. Thanks a ton.
Old 12th November 2017, 01:38 AM   #13
Zero D is offline Zero D  United Kingdom
@ LightBit
I was going to post similar to what Ultima Thule has about The other version of Java you could use. So good for him being one step ahead This version is a LOT smaller install than the usual Java =
Room EQ Wizard uses it in the version i have. From REW's log.
HotSpot Client Compiler
REW uses classes from other jars in addition to its own RoomEQ_Wizard_obf.jar jar file.
These are: jh.jar, comm.jar, TableLayout.jar, vecmath.jar and parallelcolt-0.8.jar. For OS X REW also uses AppleJavaExtensions.jar, and for Windows registry.jar, jasiohost.dll, jasiohost64.dll and ICE_JNITRegistry.dll are used.
All must be in the same directory as the RoomEQ_Wizard_obf jar.
To run REW just double-click the RoomEQ_Wizard_obf.jar or use the command:
java -jar RoomEQ_Wizard_obf.jar
Under Linux REW uses the Metal look and feel.
So would be nice for Everyone
Rice Kellog still going strong Not sent from a SpyPhone with CrapApps etc
Old 12th November 2017, 05:23 PM   #14
LightBit is offline LightBit  Slovenia
LightBit's Avatar
Originally Posted by Ultima Thule View Post
Great to hear you are going to use OpenJDK! Are you also going to use HotSpot JVM?
I already use OpenJDK. HotSpot JVM is just part of JRE so it won't work.
SpeakerSim should work with any Java 6 compatible runtime that has Swing support.
And will it be possible to run your program in an isolated/stand alone installation which doesn't require JVM installed on the machine (sort of "portable")?
I will look in possibility of making installer for Windows that bundles minimal JRE. REW installation with JRE is 30MB so I should be able to do at least as small as REW.
Well, I didn't release the source code yet, but I think I will do so for V1 or before. Would like to polish the code first and I have to decide which license to use.
Nice to hear that, since I didn't test it on Mac.
Old 18th November 2017, 08:32 PM   #15
LightBit's Avatar
Active filters added.
I'm marking releases with date of build. Current is 2017-11-18.
Old 23rd November 2017, 07:34 PM   #16
LightBit's Avatar
New version 2017-11-23:
  • Filter graph added
  • Amplifier active filters didn't refresh immediately after editing (fixed)
Old 27th November 2017, 02:00 PM   #17
JMB is offline JMB  United States
Where would one click to start the program? Sorry for the simple question. I downloaded the update and I am not sure where to start.
Old 27th November 2017, 02:16 PM   #18
Stixx is offline Stixx  Germany
Stixx's Avatar
The simulation window is always active...
you have to create a project, input all the data etc., and only then will it start automatically.
Probably with an error message first because you sure forgot something (I did ).
Takes a bit getting used to, but works. And you have to create a filter network first to get a display of a response.
A very simple will do, all values at zero. The program just needs something to start calculating=simulating.
www.original-ton.net
Old 27th November 2017, 06:11 PM   #19
LightBit's Avatar
It should work by double clicking it, if you have Java installed (otherwise you have to install Java first).
Is that what are you asking?
Old 27th November 2017, 07:09 PM   #20
LightBit's Avatar
Do you remember what you forgot, so I can prevent error message.
Speaker directly under Amplifier should work fine. Can you describe how exactly you have added Speaker. It could be refreshing issue. I have just fixed some.
New version 2017-11-27:
  • Save changes dialog didn't show when moving items in tree (fixed)
  • Unnecessary double enclosure recalculation removed
  • Filters didn't refresh properly
SpeakerSim speaker simulation softwareHide this!Advertise here!
speaker simulation software for Mac OSX rebojorge Multi-Way 24 17th January 2016 09:07 PM
simulation software hacknet Tubes / Valves 6 15th December 2005 03:11 PM
Speaker measurement and simulation software? Few Multi-Way 8 4th June 2004 09:31 AM
Software speaker simulation weirdness jteef Multi-Way 6 12th January 2002 09:59 AM
