Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Lundahl LL1545A LTSpice Simulation Issues
Old 2nd November 2017, 02:04 PM   #1
lemon is offline lemon  Greece
Default Lundahl LL1545A LTSpice Simulation Issues
Transformer LTSpice simulation issue.
I tried to LTSpice simulate a Lundahl LL1545A transformer to the AK4490 differential dac output, but I have FR simulation issue.
I have done an internet search about how is the right transformer LTSpice setup but the information are less.
For example, see for the Lundahl LL1545A the right LTSpice setup will be like 2 primaries coils and 4 secondaries coils with K L1 L2 L3 L4 L5 L6 0.999 spice directive.
I have done the following schematics.
If you done a real FR measurement with 20K load on the above setup by Spectrum Analyser or oscilloscope or rms multimeter, you will see that FR output is flat btw 20-15KHz, with a small increase voltage btw 17K-50K and then there is significant decrease until cut-off.
The best FR output that I have with LTSpice is the following, that is wrong.
The LTSpice have a dialogue window for Coil setup like this.
But for the example, if you measure each primary coil by DER EE DE-5000 you have the following table.
How is the right setup on LTSpice, can someone help?
I have included and the LTSpice .asc file
Old 2nd November 2017, 03:00 PM   #2
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
A couple of issues you have - firstly the series resistance of the windings needs to come from Lundahl's own data (305R for primaries, 122R and 182R for secondaries). Sorting this out fixes up the frequency response very nicely (I zeroed your shunt resistance and capacitance though to get clear what's happening initially). With the correct series R I get -1dB at almost 400kHz.
Second the inductances of a transformer depend on the frequency (and to some extent the amplitude used to measure with). The turns ratio comes out of the ratio of inductances so its best to tweak the secondary inductance to be in line with what the turns ratio is.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 2nd November 2017, 03:30 PM   #3
pieter t is offline pieter t  Netherlands
Take care: with for example 1:2 turn ratio the inductance ratio is 1:4.
Old 2nd November 2017, 04:36 PM   #4
6k7 resistor and 470 pF capacitor should be in series; sim is wrong.
Old 2nd November 2017, 04:39 PM   #5
@ abraxalito = From Lundahl's datasheet the 305R for primaries, 122R and 182R for secondaries, are described like static resistance and not series resistance.
Probably it is the same, but I confused with the Rs (Series Resistance) and Rp (Parallele Resistance) of De-ee measurings.
@ pieter t = like 5H on primaries inductance and 20H at the secondaries (in series)?
Abraxalito, can you attach me the file that you described like -1dB at 400K?
Here a new .asc file with the Lundhal's datasheet values.
Thanks for the help guys!
Old 2nd November 2017, 04:43 PM   #6
The datasheet says "Frequency response (source 600 Ohm, load (6.7 k + 470 pF) in parallel with 56 k ).
I think that it means in series the 6K7+470p and all of this parallel to the output.
Old 2nd November 2017, 04:45 PM   #7
When I am right you use the transformer with 1:1 ratio (2+2:1+1+1+1).
Then you must have equal inductance for the primary and secondary.
Old 2nd November 2017, 04:47 PM   #8
Right, but that's not what you did in the sim.
Old 2nd November 2017, 05:27 PM   #9
Oops, it is clear to me now!!
pieter t you had right, my sim is wrong, I have the R//C at the output.
Now, it is very close to the real measurement.
I have used the Series Inductance that I have measured with De-ee at 1KHz, 8.3H in primaries and 2H at primaries.
With the inductance ratio 1:4 (Prim. to Sec. ratio 1:2) which is the right?
Old 2nd November 2017, 06:02 PM   #10
Wrong typo...I meant "I have used the Series Inductance that I have measured with De-ee at 1KHz, 8.3H in each primary and 2H at each secondary.
Lundahl LL1545A LTSpice Simulation IssuesHide this!Advertise here!
Lundahl LL1545A and 50Hz hum lemon Analog Line Level 4 9th October 2015 10:27 AM
Distortion simulation with LTspice tiagor Solid State 32 22nd December 2012 09:33 PM
Lundahl LL1545A hookup question... pinnocchio Analog Line Level 2 13th September 2012 07:53 PM
LTspice simulation 8409513 Power Supplies 2 28th May 2012 03:02 PM
About LTSpice Simulation. nicholas1113 Solid State 2 15th November 2009 07:52 AM
