Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Lundahl LL1545A LTSpice Simulation Issues
Old 5th November 2017, 12:58 PM   #21
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by lemon View Post
You haven't missing something, sure.
It is the name that has, from the designers.
Super V/i converted (LL1684 )
In reality, the author of this schematic is Stefano Perugini, he has published this article at 1998.
A 24 Bit DAC, the Full Glass Audio Article
Ahh yes, I see. Happens often, someone give a nonsense name and it keeps on living ... ;-)
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 5th November 2017, 01:28 PM   #22
lemon is offline lemon  Greece
Originally Posted by pieter t View Post
Why do you take the secondaries (9-10 and 15-16) as primaries, and the primaries as secondaries?
It makes a difference, and Lundahl is clear about this!
When you use the transformer 1:1 (but for some reason you have not been able to confirm that until now) the only thing to do is to short the two wires of your combined secondary for measuring leakage inductance, no need to "short all secondaries" as you should have created just one secondary....
The Lundahl datasheet says, that is an alternative connection and gives some samples (page 2) about this.
This reverse direction causes a different K to 1:1 ratio?
I hadn't any reason to keep it secret, for this reason at my first postage write "...will be like 2 primaries coils and 4 secondaries coils ..." and at the schema below from this seems clearly that I have 4 L in series at the secondaries and 2 in the primaries like alternative connection.
Anyway, I will repeat the measurement of leak.ind. as you described.
Thnx for the note.
Lundahl LL1545A LTSpice Simulation IssuesHide this!Advertise here!
Lundahl LL1545A and 50Hz hum lemon Analog Line Level 4 9th October 2015 10:27 AM
Distortion simulation with LTspice tiagor Solid State 32 22nd December 2012 09:33 PM
Lundahl LL1545A hookup question... pinnocchio Analog Line Level 2 13th September 2012 07:53 PM
LTspice simulation 8409513 Power Supplies 2 28th May 2012 03:02 PM
About LTSpice Simulation. nicholas1113 Solid State 2 15th November 2009 07:52 AM
