Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Software to Predict Directivity
Old 17th October 2017, 01:39 AM   #1
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Default Software to Predict Directivity
For the last day or so, I've been messing around with Horbach Keele filters.
This absolutely blows my mind, but there does not appear to be any software available to simulate the directivity of an array.
I have a difficult time believing this; many of you have built arrays. How on earth is there no software to do this?
Here's a list of what I've looked at:
7) Akabak - it can simulate the directivity of an array, but only at a single frequency.
6) ABEC - can simulate the directivity of an array, but you'll spend the next two years of your life creating the model
5) Hornresp - can simulate the directivity of a single driver, not an array
4) VituixCad - I had really high hopes for this. As far as I can see, it can display the measurements that you make, but I don't see any way for it to simulate the performance of a driver based on it's diameter. IE, it can sim arrays as long as you actually build and measure the array first.
3) XDIR - it can simulate an array. It has no ability to include a crossover. I guess you could get 'in the ballpark' if you calculated the crossover phase shift manually.
2) FRD Consortium's VPR can do arrays, but can't do xovers
1) At the moment, the closing thing to a working array simulator is FRD Consortium's ARPE. But the website has been dead for years, and the software can't do bandpass filters properly. Which means I can't sim Horbach Keele filters.
Please tell me there's software that can do this. I don't want to write my own.
Old 17th October 2017, 03:44 AM   #2
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
You know that xcel could effectively do that?
Not that setting it up would be exactly quick....
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 17th October 2017, 04:37 AM   #3
Microsoft Excel?
The ARPE spreadsheets seems to be the closest I can get to my goal. But it can't do proper bandpass filters.
Might be worthwhile to dig into the source code if it's not protected...
Old 17th October 2017, 05:48 AM   #4
kessito is offline kessito  Netherlands
Use abec, really.
If you use the point source model in abec instead of bem it becomes much much more easy and it does what you need it to do.
One day you will have to bite the bullit; if you master abec you can throw all other sim software aside.
Cheers
Old 17th October 2017, 06:16 AM   #5
LightBit is online now LightBit  Slovenia
LightBit's Avatar
I believe BoxSim does what you want, but it is for Visaton drivers.
Currently I'm working on simulation software that can (if I understand) do that. I can give it to you, but it isn't finished yet (only passive filters, ...).
Old 23rd October 2017, 01:09 PM   #6
evilnui is offline evilnui
That depends heavily on what you are modelling. The actual simulation may take longer if you want accuracy up to high frequencies :P
Are you talking direct drivers like the authors you mentioned, or do you want to array synergies or something?
@ kessito
I have not used abec with point models yet. Then again, I used it to play around with horns/waveguides and explicitly desired models closer to a real build.
Old 23rd October 2017, 08:17 PM   #7
@ kessito
Something like ARPE. Where you can specify the diameter of a radiator and it's location, and ARPE will figure out the polar response.
ABEC can do this, but it's so freakin' dreadful to create all the elements.
Old 23rd October 2017, 08:35 PM   #8
Since I don't see any mention of an enclosure there I might be able to give you a slight head start or headache, who knows.
I dont ABEC supporst FIR filters, so I think you have to produce pre-filtered responses per driver and import those in abec...
The following code produces this with 5 different "drivers" with 4 pairs and one in the center. It follows the specs by the aforementioned authors of some 5-way design (though that one was vertical).
In the formula section you can change the diameter and distance of individual drivers.
Let me warn you though. For some reason my polar response is lopsided and I have no idea why.
Add as a direct sound script.
Code:
Subdomain_Properties
	Subdomain=1
	ElType=Exterior
	//IBPlane=z
formula
	bh = 20*2.54*0.01 //mm
	bw = 80*2.54*0.01 //mm
	bd = 30*0.01
	d1d = 1*2.54 //cm
	d2d = 2*2.54 //cm
	d2t = 1.5*2.54 //cm
	d3d = 4*2.54 //cm
	d3t = 4.5*2.54
	d4d = 8*2.54 //cm
	d4t = 12.5*2.54
	d5d = 15*2.54 //cm
	d5t = 31.25*2.54
Nodes "N"
	scale=1cm
	11 0 0 0
	21 { d2t} 0 0
	22 {-d2t} 0 0
	31 { d3t} 0 0
	32 {-d3t} 0 0
	41 { d4t} 0 0
	42 {-d4t} 0 0
	51 { d5t} 0 0
	52 {-d5t} 0 0
Pressure_Box "drv1"
	Subdomain=1
	DrvGroup=11
	DiaphShape=Disc
	dD=1 in
Pressure_Box "drv2r"
	Subdomain=1
	DrvGroup=21
	DiaphShape=Disc
	dD={d2d*0.01}
	RefNodes="N"
	Position=21
Pressure_Box "drv2l"
	Subdomain=1
	DrvGroup=22
	DiaphShape=Disc
	dD={d2d*0.01}
	RefNodes="N"
	Position=22
Pressure_Box "drv3r"
	Subdomain=1
	DrvGroup=31
	DiaphShape=Disc
	dD={d3d*0.01}
	RefNodes="N"
	Position=31
Pressure_Box "drv3l"
	Subdomain=1
	DrvGroup=32
	DiaphShape=Disc
	dD={d3d*0.01}
	RefNodes="N"
	Position=32
Pressure_Box "drv4r"
	Subdomain=1
	DrvGroup=41
	DiaphShape=Disc
	dD={d4d*0.01}
	RefNodes="N"
	Position=41
Pressure_Box "drv4l"
	Subdomain=1
	DrvGroup=42
	DiaphShape=Disc
	dD={d4d*0.01}
	RefNodes="N"
	Position=42
Pressure_Box "drv5r"
	Subdomain=1
	DrvGroup=51
	DiaphShape=Disc
	dD={d5d*0.01}
	RefNodes="N"
	Position=51
Pressure_Box "drv5l"
	Subdomain=1
	DrvGroup=52
	DiaphShape=Disc
	dD={d5d*0.01}
	RefNodes="N"
	Position=52
And as a bonus here is a bem solution without external CAD help. Solving this takes a while even at settings that won't allow useful resolution at higher frequencies.
by bem script
Code:
Control_Solver
	f1				=20Hz;
	f2				=10kHz;
	MeshFrequency	=10kHz;
	NumFrequencies	=50; Abscissa=log
	//Meshing=Delaunay
	//Meshing=BiFu
    Sym=y
    Dim=3D
	//NUC=false
	Subdomain=1
	ElType=Exterior
	//IBPlane=z
formula
	bd = 30*0.01
	d1d = 1*2.54 //cm
	d2d = 2*2.54 //cm
	d2t = 1.5*2.54 //cm
	d3d = 4*2.54 //cm
	d3t = 4.5*2.54
	d4d = 8*2.54 //cm
	d4t = 12.5*2.54
	d5d = 15*2.54 //cm
	d5t = 31.25*2.54
Nodes "N"
	1001 {-bw/2} {bh/2} 0
	1002 {-bw/2} {   0} 0
	1003 { bw/2} {   0} 0
	1004 { bw/2} {bh/2} 0
	1011 {-bw/2} {bh/2} {-bd}
	1012 {-bw/2} {   0} {-bd}
	1013 { bw/2} {   0} {-bd}
	1014 { bw/2} {bh/2} {-bd}
Elements "enclosure"
	Subdomain=1
	RefNodes="N"
	MeshFrequency=500Hz
	SwapNormals
	101 1001 1002 1012 1011
	102 1001 1011 1014 1004
	103 1003 1004 1014 1013
	104 1011 1012 1013 1014
	//105 1002 1003 1013 1012
Baffle "front"
	Subdomain=1
	Position=z
	MeshFrequency=2kHz
	hB = {bh}
	wB = {bw}
	11 Ref="d1" x=0 y=0
	21 Ref="d2r" x={ d2t*0.01} y=0
	22 Ref="d2l" x={-d2t*0.01} y=0
	31 Ref="d3r" x={ d3t*0.01} y=0
	32 Ref="d3l" x={-d3t*0.01} y=0
	41 Ref="d4r" x={ d4t*0.01} y=0
	42 Ref="d4l" x={-d4t*0.01} y=0
	51 Ref="d5r" x={ d5t*0.01} y=0
	52 Ref="d5l" x={-d5t*0.01} y=0
Diaphragm "d1"
	Subdomain=1
	DrvGroup=11
	dD={d1d*0.01}
	MeshFrequency=10kHz
	simple
Diaphragm "d2r"
	Subdomain=1
	DrvGroup=21
	dD={d2d*0.01}
	simple
Diaphragm "d2l"
	Subdomain=1
	DrvGroup=22
	dD={d2d*0.01}
	simple
Diaphragm "d3r"
	Subdomain=1
	DrvGroup=31
	dD={d3d*0.01}
	MeshFrequency=8kHz
	simple
Diaphragm "d3l"
	Subdomain=1
	DrvGroup=32
	dD={d3d*0.01}
	MeshFrequency=8kHz
	simple
Diaphragm "d4r"
	Subdomain=1
	DrvGroup=41
	dD={d4d*0.01}
	MeshFrequency=4kHz
	simple
Diaphragm "d4l"
	Subdomain=1
	DrvGroup=42
	dD={d4d*0.01}
	MeshFrequency=4kHz
	simple
Diaphragm "d5r"
	Subdomain=1
	DrvGroup=51
	dD={d5d*0.01}
	MeshFrequency=2kHz
	simple
Diaphragm "d5l"
	Subdomain=1
	DrvGroup=52
	dD={d5d*0.01}
	MeshFrequency=2kHz
	simple
Old 23rd October 2017, 08:44 PM   #9
Wow, that's very helpful. I tried to learn ABEC using a thread on a German forum. But trying to learn a difficult piece of software via a tutorial in German is an uphill battle.
My home computer is kind of a beast, I have sixteen Xeon cores so sim times aren't much of an issue (Waveguide model)
Old 23rd October 2017, 09:00 PM   #10
Perhaps you were on diy-hifi-forum.eu?
I fought my own battles with this software today. Far too often I suffer from silent errors. Everything seems to be simulated, but the results are garbage, or almost nonexistant. It's really annoying to then stare at the scripts to see what could have gone wrong.
Interesting solution with that server. I'll get a taste of that with my next machine, as it might just be an 8 core ryzen
And since you may have missed my sneaky edit above. It is missing the crossover and I think you'll have to feed ABEC with pre-filtered responses for each driver to use FIR filters.
Software to Predict DirectivityHide this!Advertise here!
Predict this Toggle Circuits behavior imix500 Parts 58 5th September 2006 02:40 AM
What do you predict the Mackie SRM350 will be like? rintincop2 Multi-Way 2 25th September 2004 07:46 AM
How to predict PSRR ? Kilentra Solid State 6 9th July 2004 07:31 PM
