Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
How to calculate SPL with filters in Excel
Old 25th September 2017, 03:10 PM   #1
Windforce85 is offline Windforce85  Poland
Default How to calculate SPL with filters in Excel
Hi there,
Maybe this is stupid question but I have never been good in math.
I made xls spreadsheet where I can calculate SPL, excursion, impedance and power of driver in sealed boxes in function of frequency. I am struggled becouse I also would like to calculate transfer function of various filters in Excel and to plot its influence on SPL curves. Unfortunately I cannot find clear and easy to implement set of formulae to calculate it in function of frequency giving Q, f and n of the filters. Do you know good source of such formulae? Thanks!
What I need to do (this is only an example):
filter:
Butterworth
order:
2
corner freq:
10 Hz
freq. raw SPL filtered SPL
10 Hz 60 dB 55 dB
11 Hz 62 dB 53 dB
12 Hz 64 dB 51 dB
13 Hz 66 dB 49 dB
Thanks!
Old 25th September 2017, 11:44 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
2nd order transfer functions
HP
H(s)=s^2/(s^2+s*wo/Q+wo^2)
LP
H(s)=wo^2/(s^2+s*wo/Q+wo^2)
wo=filter cutoff
s=complex frequency
Q is Q
Butterworth Q is 0.707
Linkwitz Riley 0.5
Bessel 0.577
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 26th September 2017, 11:29 AM   #3
Thanks,
But still I quite don't know how to interpret "complex frequency" term. If I substitute 's' with sound frequency in cycles per second (Hz) I am still getting wrong results from this formulae.
Old 26th September 2017, 01:09 PM   #4
djoffe is offline djoffe  United States
This guy talks about doing complex number calculations in Excel:
Complex Numbers in Excel | EngineerExcel
If you don't want to go through all that, you could use these formulas (see enclosed picture).
www.akitika.com Featuring the GT-102 Power Amp and PR-101 Preamp kits
www.updatemydynaco.com Featuring upgrades for classic Dynaco Solid State Equipment
Old 26th September 2017, 01:35 PM   #5
R.I.P.
your results Raw vs Filtered show the SPL going down as frequency increases.
This seems to be a low pass filter.
Surely your 10Hz filter should be a high pass.
regards Andrew T.
Old 26th September 2017, 04:19 PM   #6
Hi, this works nice, thanks! However it is still only 2nd order. Are there a formulae which involves filter order into calculations? For example when designing odd order Butterworth slopes?
Old 26th September 2017, 05:07 PM   #7
aczern is offline aczern
Do you know this book?
Old 26th September 2017, 05:11 PM   #8
CharlieLaub is offline CharlieLaub  United States
I became very skilled at Excel filter calculations when I wrote my "Active Crossover Designer" Excel tools. See my web page:
the Active Crossover Designer web page
You need to be able to calculate the filer response using complex numbers. The complex number includes an amplitude and phase component. At the end you back out the scalar quantities magnitude and phase from the complex number and convert magnitude to SPL and phase to degrees.
Excel has a set of built in complex number functions that are very complete, but a bit clumsy to work with. My ACD spreadsheets do not include any hidden sheets and all formulas can be looked at. You are welcome to use them as a resource on how to do filter calcs in Excel, and then create your own version or feel free to use ACD.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 26th September 2017, 08:07 PM   #9
Great Thanks Charlie!
Your formulas and overal level of Excel operations inside are well beyond my level of understanding and imagination. I've got few inspirations from you for troubleshooting and handling of my simple formulas.
I don't know how you've made log-scaled x axis but there it is (I wasn't able to do it on my own) so I've borrowed your graph layout to my spreadsheet if you don't mind.
To everyone. I am working on one tool which can help user to design his own magnetic circuit and voice coil inside of driver. It can approximate magnetic flux density inside the gap from given neo magnet ring (or slug) dimensions. User can enter gap dimensions and VC parameters like wire gauge, number of layers, conductor type and shape, VC height etc. Then every parameter can be calculated like BI, Re, geometric Xmax, Qes etc... Then, such a driver with spec'ed by the user cone and motor properities can be simulated in sealed box and compared with production driver's database. It is still much work to be done...
Old 26th September 2017, 08:08 PM   #10
If you have the filters in factored form, that is, a cascade of 2nd order and first order sections, then you can just add the dB's provided by each section.
For a single order lowpass filter and highpass filter, we have as you see in the attached picture, where f3 is the 3 dB corner frequency. Of course, if you're looking for a general approach, Charlie's way may be the one for you.
How to calculate SPL with filters in ExcelHide this!Advertise here!
How to calculate series notch filters merlin el mago Multi-Way 41 14th March 2014 11:47 AM
anyone know how to calculate this?? kendt Construction Tips 2 7th January 2014 08:04 PM
Calculate SPL exuviae Subwoofers 3 5th July 2006 07:51 AM
help ! how to calculate?????????? bogdan_borko Solid State 3 18th January 2006 10:15 PM
EMI ac line filters & RFI ac line filters. Are they one and the same? KevinLee Parts 1 8th January 2003 12:18 AM
