New Analogue Design Tool from TI
Administrator
Joined 2007
This looked useful and interesting, a new design tool from Texas Instruments to complement the 'Analog Engineers Pocket Reference' book which is available from the same page.
DESIGN TOOL
Unzip the folder and read the pdf on installation. I did not disable Fast Start and all seems OK with W10. Just do a restart after installation to put everything in order.
You may (or may not) need to navigate to the TI folder in your program files and change the DPI scaling if you experience slightly fuzzy text on the program interface (that's a common issue with many applications). This setting is found on the shortcut for the program.
Time for a play :D
