I'm struggling with the thiele small parameters of the drivers and try to simulate them on LTSpice, but I'm not sure about how I can calculate the electric equivalent circuit impedances starting from them. I googled around and there are several persons sustaining several theories, which approximations do you use in your sims?
This was one of them:Explain "struggling"... which models did you use and know of?
http://www.har-bal.com/wp-content/uploads/Speaker_theory.pdf
I tried some different theories about converting TS parameters to an equivalent circuit but none of them seem to be reliable enough so far
- Design & Build
- Software Tools
- From Thiele Small parameters to equivalent circuit
