Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
VituixCAD
VituixCAD
Old 25th December 2017, 07:01 PM   #201
kimmosto is offline kimmosto  Finland
Looks like auto scale setting of .NET form does not freeze font size, and that could lead to some other problems. Thanks for info. Could be worth to restore official release and scaling to 100%. I'll try to avoid bad behavior in the future, though app. scaling works quite okay on win 10. Probably without problems if application windows fit on screen.
Old 26th December 2017, 09:36 AM   #202
Originally Posted by kimmosto View Post
I'll try to avoid bad behavior in the future...
Looks that custom code for Windows 7 only is too complex and not productive enough because 7 is obsolete anyway. SPL Trace alone would be piece of cake compared to custom graphics such as crossover schema.
Scaling of 100% is recommended until operating system is upgraded to Windows 10 Creators Update (1703) or later.
More information: High DPI Desktop Application Development on Windows
Old 28th December 2017, 03:53 PM   #203
Revision 1.1.25.0 (2017-12-27)
Diffraction tool: maximum amount of drivers increased from 12 to 50, and added distance between drivers (Step mm). This helps creating of long line sources with multiple domes or rectangular planars. Long planar line should be simulated as multiple small planars instead of single long.
Old 5th January 2018, 05:10 PM   #204
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
Just a heads up, it didn't cause any problems but I noticed that when I was an idiot and tried to load a PDF into your trace tool by accident, it caused an unhandled exception.
Old 5th January 2018, 07:05 PM   #205
Not surprised. *.* filter is available in Windows open dialog by default. I will add error handling to the next revision. Usually I have not added if working goes well without.
Old 5th January 2018, 07:25 PM   #206
That is now fixed in rev 1.1.25.1
Old 5th January 2018, 07:58 PM   #207
gfiandy's Avatar
Many thanks I wasn't expecting a version update just for this tiny error, I just thought you would add it to a fixes to do list.
Old 5th January 2018, 09:09 PM   #208
Length of wish list is quite short at the moment, maybe 4 features. I've not promised anything so far. I had to take a break because this has been continuous work for last two months.
Old 5th January 2018, 09:53 PM   #209
Windforce85 is offline Windforce85  Poland
Yeah becouse I did not cut myself into for some time.
Old 8th January 2018, 08:01 AM   #210
docali is offline docali  Germany
docali's Avatar
Hello!
Just discovered this awesome software a few days ago. Really great work!
You mentioned new features. What about adding autoformers as passive cross-over element? For compression drivers these are a common method to use in cross-overs and there are some really good devices available again. I am not aware how complex this would be incorporate.
VituixCADHide this!Advertise here!
