Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
VituixCAD
VituixCAD
Old 9th November 2017, 12:24 PM   #131
kimmosto is offline kimmosto  Finland
Originally Posted by DBMandrake View Post
Depending on how I measure it the acoustic offset between the drivers is between 35-50mm.
Not so moderate distance anymore. Few all-pass blocks could be rational enough if you don't modify existing enclosure and tilting causes too much trouble at top octave.
Old 9th November 2017, 01:02 PM   #132
DBMandrake is offline DBMandrake  Scotland
DBMandrake's Avatar
Yes it is quite an offset to deal with, tilting is not an option as the the tweeter is a 50mm tall ribbon with significant vertical directivity in the top octave, so really needs to be mounted at right angles near ear height for best results.
Other than mounting the tweeter in a set back pod or using an active crossover with digital delay, I think the all-pass filters are my next best option, and I'm interested to try them anyway as I have not used this approach before in a passive crossover. So it is an interesting experiment.
Yes it's 8 extra components for the two cascade filters needed for enough delay but the close phase tracking through the crossover region, well behaved symmetrical vertical lobe, and symmetric 4th order slopes will be worthwhile in my opinion.
All the other passive options I've SIMed so far (unequal slopes, with/without reversing driver phase etc) have all performed much worse and were serious compromises.
Also they are not large components - 0.22mH and 3.5uF are quite manageable in size even with eight of them, and as the tweeter already needs about 5dB of padding I don't need bulky very low resistance coils. I have room for a crossover board in the bottom panel of the cabinet of up to about 35cm x 28cm, so I think I will have room.
- Simon
Old 22nd November 2017, 02:13 PM   #133
Revision 1.1.16.0 (2017-11-22). See changelog.
* SPL Trace improved. Dragging of boundary lines, image renewing etc.
* Added Auxiliary calculator tool. The first version includes Time window and Wave length calculators, but some others will be added later.
Old 22nd November 2017, 09:00 PM   #134
aczern is offline aczern
I suggest:
Maximum frequency for a near field measurement for the diaphragm diameter.
A time duration and a length of one or a few samples for the definite sampling frequency.
Old 23rd November 2017, 04:48 AM   #135
^Ok.
Max. frequency calculator and some warning could also be in Merger tool where Sd or Dd is entered and transition frequency finally selected. No problem to locate in Auxiliary calc. fNFmax=c/2/pi/r is quite simplified and rough theory but could be valuable.
Old 24th November 2017, 10:26 AM   #136
Done in rev. 1.1.17.0
Old 24th November 2017, 04:58 PM   #137
Could you remove the upper frequency limit for SPL Trace? This tool is useful for creating files for other programs too.
Old 25th November 2017, 12:27 PM   #138
It's not just a limit. Internal frequency scale (10...22k, 534 points) is global inside whole program package. Individual tool which doesn't have direct response data connection to others can be disconnected from global freq. scale by modifying some public functions. It's doable and preliminary done, but not fully tested.
Could you mention some other programs you would supply with output of SPL Trace?
Old 25th November 2017, 12:40 PM   #139
ergo is offline ergo  Estonia
My last application for VCAD SPL trace for example was to read data from lab microphone calibration chart that came with it... data goes to 40k+ so there such feature would be useful. I then transferred it to CLIO FW as cal file eventually. I had to go through LspCAD though as CLIO accepts max 100 data lines in the file (silently ignores upper frequencies if there are more than that which is quite a bad way to implement something important like calibration).
From this a potential ask would be to also be able to say how many data points should SPL trace output... but not sure how many use cases beside the CLIO case do need that.
LspCAD would support upto data upto 50k.
Ergo
Old 25th November 2017, 02:47 PM   #140
ARTA - a microphone calibration file made from a picture
LspCAD - frequency and impedance responses from a datasheet
Xover - as above
VituixCADHide this!Advertise here!
