Hi there.
It's quasi's nbip300 - https://sites.google.com/site/quasisdiyaudiosite/nbip-series/nbip300
There's quite the thread here on Diyaudio, and I pulled the .Lay file from there (slightly different layout, but essentially the same)
.Lay are sprint's format. The trial of sprint, doesn't allow any outputs, so I'm left with a PDF for Toner transfer or asking for help!
Hi Jan, I did try to get in touch, via email and here, to no joy. In fairness, quasi has made available the .Lay and a PDF of the tracks, so I do have all I need to do the job; I'm merely held back by my own basic lack of skill/tools.
Hi jazbo, I actually did do exactly that, with some press and peel paper and a USB stick, and eventually gave up trying to get it done there after a number of failed attempts. :/ I'm back at work as of today, so I'll try using the printer there, but quite frankly, I've now burnt more time on this pcb than makes any sort of sense.
Hence the 'send it to a fab' idea basically! It's turning out to be a lot of diy time spent justifying the pile of 2n3773's I have here.
- Design & Build
- Software Tools
- Could someone help me out and convert this .lay to gerber
