Help Needed Please - Copy/Paste Batch File - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 2nd October 2016, 03:28 PM   #1
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Default Help Needed Please - Copy/Paste Batch File
Maybe some batch file kings here can solve this for me please.
I need a batch file that will copy a Folder or File from one drive to another and back, a defined number of times.
Something like....
Step 01.....Copy D:/Transfers - 00 to F:/ and rename to F:/Transfers - 01
Step 02.....Copy F:/Transfers - 01 to D:/ and rename to D:/Transfers - 02
and so on a defined number of times, and perhaps with a defined time delay between transfers.
So the same Folder or File is copied back and forth between the drives and builds numbered directory lists, with odd numbers of transfers stored on F:, and even numbers of transfers stored on D:.
I have tried doing this manually but it becomes tedious and is prone to error, and there seems to be an issue with the clipboard writing the new file and not actually a drive to drive data transfer.
Any help will be very much appreciated.
Dan.
Old 4th October 2016, 11:39 PM   #2
Bump.
Dan.
Old 5th October 2016, 12:11 AM   #3
Methinks you're going to need the MSDOS commands set and if . You'll probably use the /a flag with the set commend ... tells DOS the right hand side of the equals sign is a numerical quantity, i.e., this is an arithmetic set. a is the flag for arithmetic.
Old 5th October 2016, 03:16 AM   #4
Thanks Mark, I do understand that a DOS routine is the deal.
Trouble is I have never bothered to learn msdos properly, let alone higher languages.
I need all the help I can get .
Dan.
Old 5th October 2016, 03:35 AM   #5
DUG is offline DUG  Canada
Here?
MS-DOS copy command help
or
DOS Command: COPY
(first two google search results)
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
PDF layouts: copy/paste, multiple on a single page TroelsM Construction Tips 3 19th April 2015 12:37 AM
Help with SPL COPY and .frd file extraction iFearFractals Multi-Way 5 1st July 2014 05:50 PM
notes / copy+paste tomtt The Lounge 4 31st March 2010 03:30 AM
Triangle audio file needed Bernhard Digital Source 1 17th July 2006 09:38 AM
Traxmaker copy paste problem? promitheus Everything Else 2 22nd January 2004 10:23 AM
Copyright 1999-2017 diyAudio
