So my design dictates a port that is 76.29 cm in length. I have drawn a slot port in SketchUp but am not sure how the length of it is calculated. I think I might need to add a few more centimeters.
I'm including a screenshot with dimensions. Please let me know if I got it right.
Thanks!
Thanks!
Measure in the axis of the port from end/inside to baffle/outside. 1 or more centimeters is fine. (I guess you have less) Calibrate by ear/listening in the end.
I'm not quite sure I understand. Do I measure just the wood pieces, not the space between them?
There pieces are 43.7 cm + 28.1 cm, and the depth of the front baffle (double baffle) is 3.6 cm, so my port is 3.6 + 43.7 + 28.1 = 75.4 cm? So I add 0.9 cm and that's it?
You can count (43.7 cm + 46.4 cm)/2 + 3.6 cm + 28.1 cm and that will be very close. What alignment are you using, and driver?!
Why did you add 43.7 and 46.4 and divide them by two?
Not sure what you mean by alignment. The driver is an Infinity 1260w.
You mention in the drawing those two measures to give the axis of the bottom part of the slot port (). By the way alignment is the net volume and tuning frequency.
I mentioned the longer part to show the distance between the first (lower) part of the port and the rear panel of the sub.
So, you have close to 76.75 cm total what is close to the "76.29 cm in length" you mention in post #1.I mentioned the longer part to show the distance between the first (lower) part of the port and the rear panel of the sub.
Yeah but I wasn't sure what to measure exactly, the length of the panels that comprise the vent, or in the middle between them. I have figured it out already, though, and I made a small correction of 1.9 cm.
Now I need to add bracing to the design and it's ready to be sent to the carpenter. Suggestions?
- Design & Build
- Software Tools
- Need a little help with sketching sub box in SketchUp (specifically the port length)
