Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
How to sample AC signal for RMS level calculation
Old 28th March 2016, 06:25 PM   #1
Wiggle8 is offline Wiggle8  Canada
Default How to sample AC signal for RMS level calculation
I am trying to add an Arduino microprocessor to a power amplifier to display internal temperature and power of output at the speaker terminals on an LCD display.
However, I am having some trouble determining the best way to measure the voltage and current due to them being AC signals. Here is my best guess at a method, let me know if it sounds reasonable:
Use a biasing circuit to make sure all AC signals are translated into a 0-5V measurement range for all operating conditions. Was going to use something such as this: https://openenergymonitor.org/emon/b...sors-interface
I would then convert this measurement to a value by saying:
VALUE=abs((INPUT-2.5))*scalingfactor
(where scalingfactor is the correction factor to convert measurement voltage back to "real" V or A)
Calculating an RMS value for my power calculation is where I am struggling. Is it reasonable to simply collect a good amount of data points (say 20) over a period of 0.25 seconds, store them in an array, square each value and then divide out the number of samples and take the square root?
RMS=sqrt((sum(VALUE[i]*2, i=0..20))/i)
(where i is the number of samples)
Let me know if I am totally confused or on the right track
Old 29th March 2016, 07:53 AM   #2
deanoUK is offline deanoUK  United Kingdom
Rectify the signal to get DC.
Old 29th March 2016, 08:08 AM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
Haven't used arduino for signal processing. I think arduino is pretty slow, maybe 5-10kS/s, you would want at least 40kS/s or you will only read power data below half the sampling rate and could have aliasing issues.
Google for 'RMS to DC converter' - adding arduino to that search reveals quite a few results, but I haven't read any
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 29th March 2016, 08:46 AM   #4
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I think you would integrated each area under two consecutive samples, no?
BTW I have a similar project where I use an AD536 AC to RMS converter feeding into a PIC ADC pin. Works like a charm.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 29th March 2016, 12:06 PM   #5
Will I not lose a big chunk of my signal due to the forward voltage on the rectifiers?
Old 29th March 2016, 12:07 PM   #6
Thanks, yep I am aware of the aliasing issues. But I am not looking to adequately sample the signal, only average out the amplitude of the signal for a rough calculation of output power.
Old 29th March 2016, 12:23 PM   #7
Jan
That AD536 looks ideal, sadly at the cost though I'd be spending over $100 for them though for the number of inputs I was hoping to use.
Old 29th March 2016, 12:31 PM   #8
jan.didden's Avatar
You could mux the input.
Old 29th March 2016, 02:57 PM   #9
Ron E's Avatar
https://en.wikipedia.org/wiki/True_R...nic_converters
There is a way to make a "precision diode" (no forward voltage) using an op amp and a diode, and you can buffer the circuit to keep it from loading the source.
http://forum.allaboutcircuits.com/th...ctifier.64943/
Old 29th March 2016, 03:31 PM   #10
cbdb is offline cbdb  Canada
Find an opamp circuit book or even at the end of some opamp data sheets and you will find a Rams detector built with opamps. Or Google opamp Rams detector.
How to sample AC signal for RMS level calculationHide this!Advertise here!
Chip Amplifier input signal calculation tahir4awan Chip Amps 6 1st March 2015 05:46 AM
signal level sakshi Analog Line Level 2 31st December 2012 11:40 AM
How do I turn an high current signal into a line level signal?? sardonx Tubes / Valves 8 27th August 2005 11:16 AM
how to bring down line level signal to preamplifier level deji Solid State 15 15th April 2004 04:13 PM
Calculation of RMS power output? protos Solid State 47 1st February 2003 08:11 AM
