pls help tp simulate transcond TDA2003 amp
continued...
to opamp1 from ltspice I connected the name TDA2003, maybe the connection the model to circuit needs more operations?
I think DUG is correct, you have a direct ground conection to the inverting input. It doesn't mater that the output is AC coupled, the input pin is still ground referenced.
(your .asc file wont run on a default LT installation. There are unknown models and subcircuits being called up that aren't included in your file)
please advise
how to create sub and cir files of TDA2003
with this model:
* IN+
* | IN-
* | | GND
* | | | OUT
* | | | | VPLUS
.SUBCKT TDA2003 1 2 3 4 5
R_R6 1 N_1 150K
RCON_TAG2 1 0 1G
V_VOS2 N_2 2 0.65V
R_R8 5 N_3 20K
V_VOS1 N_1 3 1.3V
F_F1 2 3 VF_F1 0.5
VF_F1 N_3 3 1.8V
** Text Force **
.MODEL D D
D_D1 N_4 N_5 D
RCON_TAG3 N_6 0 1G
G_G1 N_7 N_6 VALUE { 5A*TANH(450*V(N_8, N_6)) }
R_R7 2 4 20K
F_F3 N_4 5 VF_F3 1
VF_F3 5 N_7 0
D_D2 5 N_4 D
R_RNOF1 5 4 1G
RFUD1 N_9 N_8 1
RFUD2 N_8 0 1G
RCON_TAG4 N_9 0 1G
R_RNOF2 4 3 1G
C_COUT 4 3 5pF
F_F2 5 3 VF_F2 1
VF_F2 N_5 5 0
X_U1 1 N_2 N_9 5 3 OpAmpConfigRails PARAMS: GDC=100K GBW=10 SLEW=1
+ ROUT=100 PM=45 VMP=0.65 VMN=0.65 W=10m
R_ROUT N_6 4 120m
.ENDS TDA2003
