PCB Layout Software Advice - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 17th August 2015, 03:38 PM   #1
fasterbyelan's Avatar
Default PCB Layout Software Advice
I need to learn how to design my own PCB's via one of the shareware packages. Having become familiar with LTSpice I would ideally like to be able to import designs into the package. Is this possible to do this with KiCad for example?
Karl
Lenco - cause it's got soul!
Old 21st August 2015, 01:30 PM   #2
Anyone?
Karl
Old 21st August 2015, 01:52 PM   #3
Hi fasterbyelan,
Can't say much about the KiCad. Tried it but dropped for some reason. Now I use the Eagle CAD. It appeared easy to learn and use. It has free licence for hobby use.
Oleg
Old 21st August 2015, 02:27 PM   #4
Most packages at some stage use an intermediate file called a netlist (.net) to transfer schematic to layout. This will be a text file, usually using a fairly standard format. With a bit of editing in a text editor, maybe using a few macros, you should be able to translate and transfer between most softwares.
Now I am Become Death, the Destroyer of Words
Old 21st August 2015, 05:34 PM   #5
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
counter culture gave some useful hints. also, you can do a search and find that andy_c, who used to post to this site, posted some info on how to use LT Spice as schematic capture "front end" for the layout program FreePCB.
FreePCB is a decent enough program.
good luck!
mlloyd1
Old 24th August 2015, 11:07 AM   #6
Thanks for the info/replies
I have the use of KiCad at work hence the preference for that software. However, as I am not familiar with it there is no advantage to be had so I will give FreePCB a go and search the site for relevant info as suggested
Thanks again,
Karl
Old 24th August 2015, 12:48 PM   #7
For info andy_c's thread on the DIYHiFi.org forum -
DIYHiFi.org • View topic - Howto: Use LTSpice as schematic capture for FreePCB
Karl
Old 25th August 2015, 06:13 AM   #8
Originally Posted by fasterbyelan View Post
This is a similar version of the above but in a single doc, probably easier to work with -
Using LTspice With FreePCB
Karl
Old 25th August 2015, 11:23 AM   #9
gannaji is offline gannaji  India
Please see this thread also!
Lt-FreePcb : LTSpice and FreePcb working together
www.samritatrust.org
PCB layout software rtarbell Parts 1 10th January 2006 09:42 PM
PCB Layout software thomasfw Everything Else 5 21st April 2005 05:02 PM
PCB Layout Software Apogee Everything Else 33 17th July 2002 07:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
