Help With Frequency Response Curve - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 16th July 2015, 08:28 AM   #1
Default Help With Frequency Response Curve
Hello,
I am wondering if someone can provide advice. So I built some test speakers and ran a linear sine wave frequency sweep through them. Using my iPhone 6, I recorded the output from 1" away. So now I am trying to put together the data. My understanding is that I have to somehow compensate for microphone frequency response?
Ultimately, I am trying to plot a frequency response curve graph. I'm using free software, Audacity. I am not sure what options I am supposed to choose for: algorithm, function, size, and axis. Again, not sure how I compensate for mic either.
Any help is appreciated. Thanks!
Old 17th July 2015, 07:58 AM   #2
Originally Posted by irishpatrick33 View Post
Hello,
There is good freeware for doing acoustical tests - Holme Impulse and Room Eq Wizard come quickly to mind. They are based on swept sines, but they also handle the analysis.
Old 21st July 2015, 05:06 PM   #3
H-E double hockey sticks, yeah you do.
Don't use the iPhone's built-in microphone if you want to make any serious measurements. There are some plug-in mics that you can purchase for the phone that are a big improvement. Example:
http://www.amazon.com/Dayton-Audio-i.../dp/B00ADR2B84
Even with this, your measurements will not be perfect, but will be more accurate than the phone mic for sure.
The best option is to use a calibrated mic ($50) but you will also need a mic preamp for it and an actual computer for data acquisition. Audacity has nothing to do with frequency measurements. You need a measurement program like ARTA.
"Hardware eventually fails. Software eventually works" - Michael Hartung
ACD LADSPA plugins - implements IIR digital crossover filters under Linux (e.g. on a Raspberry Pi, miniPC, etc.)
Please help interpret my frequency response curve lowpoke Multi-Way 5 6th April 2013 08:28 AM
in-room frequency response & transient response MCPete Multi-Way 1 8th October 2011 06:31 AM
Which is the better response curve here.... Foxx510 Multi-Way 6 21st March 2007 10:46 AM
Produce frequency response curve REALFLEO Multi-Way 1 7th February 2007 02:34 PM
Doubts on Phase Response and Frequency Response dumrum Multi-Way 11 5th April 2004 10:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
