Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
OPA2134 SPICE model
OPA2134 SPICE model
Old 2nd February 2004, 09:59 AM   #1
Helix is offline Helix  United Kingdom
Helix's Avatar
Default OPA2134 SPICE model
I am looking for a OPA2134 spice model to use in Or_cad PSPICE.
Does anyone have it or can suggest a near equivilent model?
Ted
Ted
Old 2nd February 2004, 10:27 AM   #2
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
There's a SPICE model on the TI site.
http://focus.ti.com/docs/prod/folder...#productmodels
I've not tried it but TI models are usually OK.
Chris Morriss.
Old 2nd February 2004, 10:34 AM   #3
Helix's Avatar
oh yeah, thanks...
seems obvious now
Ted
Old 14th February 2013, 12:53 PM   #4
Telstar is offline Telstar  Italy
I got the subcircuit right, but which .asy to use?
Can someone suggest me a similar opamp scheme from ltspice library to use?
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 18th August 2013, 10:00 AM   #5
keantoken is offline keantoken  United States
keantoken's Avatar
Go the LTSpice's symbol library and put opamp2 on the schematic. Paste the contents of OPA2134.LIB onto the schematic, then name the opamp OPA2134. I do this usually since it's the fastest way to get a simulation running.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 18th August 2013, 10:56 AM   #6
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
OPA2134 SPICE model
Here is one they I've set up. Just unzip into the folder you have your main asy file in and include the opa134.sub with a .include I find that much cleaner than adding into the lib dir and the asy directory. It also makes it easy to zip up an entire working model.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 31st January 2017, 01:21 AM   #7
dnk777 is offline dnk777
Tony.
I am getting an error message when I try to run a simulation where it's used.
I get: "Unknown subcircuit called in: xu3 0 n002 +12 -12 n004 opa134"
(copied the .sub into ltspiceIV/lib/sub/ and asy into ltspiceIV/lib/sym/opamps)
Old 10th December 2017, 04:38 AM   #8
Me too, just not xu3 but xu1
probably some things are different in the recent LTspice version.
Please, can somebody help to solve this issue?
Old 11th December 2017, 05:45 AM   #9
just another
wintermute's Avatar
OPA2134 SPICE model
Hmm, I'll see if I can check tonight. I don't have the new spice on my laptop or main computer, but I did install it on my duaghers laptop earlier in the year. I can't remember what I was simulating at the time but I think it was one of my existing circuits, and I don't remember having to do anything to get it working...
Tony.
Some of my photos
Old 11th December 2017, 06:04 AM   #10
just another
wintermute's Avatar
OPA2134 SPICE model
Actually I could have been clearer with the post with the attached zip file.
I actually create a separate directory for each project I work on. It is in that directory that I put the .sub and .asy files. I do not add them to the system library paths.
When you go to add the component you click on the little drop down for the component location and select the directory which you are in. The models then show up so you can pick them. Screen shot shows different models available in my synergy directory.
One of the benefits of doing it this way is that the project is completely portable and will just work on a completely vanilla install of ltSpice (at least ltspice IV)
Tony.
Some of my photos
Last edited by wintermute; 11th December 2017 at 06:06 AM. Reason: add comment on portability.
OPA2134 SPICE modelHide this!Advertise here!
Spice Model for 2SK1529 EUVL Software Tools 2 27th July 2010 12:16 AM
Help With 6v6 Spice Model porcatroya Tubes / Valves 0 5th May 2008 06:41 AM
SPICE model Prune Software Tools 6 16th October 2004 03:22 PM
Spice model doigtee Tubes / Valves 6 12th July 2003 11:42 AM
Spice model for LED? G Solid State 5 14th September 2002 03:33 AM
