LTSpice Simulation Problem - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 28th April 2015, 01:01 PM   #1
fasterbyelan's Avatar
Default LTSpice Simulation Problem
I have used LTSpice to simulate two phono ampsí I have built (and work!) as a means of getting familiar with the software. Both circuits have a DC servo to remove any offsets. When the simulation is run (ie DC op.), it will not complete the action and I have to stop the calculations (the lower left corner of the screen shows something is going on!) If I remove the DC Servo element of the circuits both will simulate correctly and the results as expected.
So why can't I run the simulations and why does the DC Servo have this effect?
One of the circuits is the HPS5.1 (see here)
Karl
Lenco - cause it's got soul!
Old 28th April 2015, 01:24 PM   #2
jan.didden's Avatar
Do you mean it takes longer than you are willing to wait? A servo introduces a feedback loop and feedback loop simulations can take a long time to complete.
How long did you wait?
Jan
If you don't change your beliefs, your life will be like this forever. Is that good news? - W. S. Maugham
Check out Linear Audio!
Old 28th April 2015, 01:40 PM   #3
Jan
Yes, I did think that was the case and left it running for 30 mins once before ending the sim. Maybe I just need to be more patience!?
Karl
Old 28th April 2015, 01:47 PM   #4
jan.didden's Avatar
I've had sims taking several hours, so maybe fire it up tonight before going to sleep
There are some things that take a long time, like very small timesteps, long sim time periods (obviously) and circuits that are close to oscillations (this forces the sim to use very small steps).
Jan
Old 28th April 2015, 01:50 PM   #5
jackinnj's Avatar
It's quicker when you use a soldering iron.
Old 28th April 2015, 01:56 PM   #6
Mooly's Avatar
If you're willing to post the .asc file we could take a look. I've simulated servos in some of my power amps and they complete in just a few seconds.
Installing and using LTspice. From beginner to advanced.
Old 28th April 2015, 02:21 PM   #7
Jan
Thanks, will do and let you know how I get on.
Karl
Old 28th April 2015, 07:23 PM   #8
I ran a sim on the HPS5.1 (DC op.) and this did complete after about 30 mins. The DC voltages are as expected with the servo in place
Now running an AC sim which is taking much longer, 2 hours and counting.......
Thanks for your advice Jan.
Karl
Old 28th April 2015, 07:36 PM   #9
jcx is offline jcx  United States
.AC don't usually take any noticeable time at all - likely its the operating point calculation having convergence problems
sometimes the operating point calc has to be "helped" with initial conditions, nodeset statement or even doing a .TRAN 1st and saving the settled operating point values
you really shouldn't jump to .AC until after you have wrung out the circuit sim in .TRAN
Distortion simulation with LTspice tiagor Solid State 32 22nd December 2012 09:33 PM
LTspice simulation 8409513 Power Supplies 2 28th May 2012 03:02 PM
How to do IMD simulation in LTspice!!! nicholas1113 Solid State 30 16th January 2010 01:15 AM
About LTSpice Simulation. nicholas1113 Solid State 2 15th November 2009 07:52 AM
LTSpice Simulation template?! ipop07 Tubes / Valves 5 13th May 2009 06:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
