Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Jal language help
Jal language help
Old 15th April 2015, 03:43 PM   #11
rsavas is offline rsavas  Canada
#1) are you able to program the original hex file into the pic device?
if no, then you are screwed!! i assume because you bought a already programmed device.
or
you figure #1 out first, then we can proceed
if i give you a new hex file & you can not program it into the device. you are asking me to buy the device,program it, & mail/send it too you?
Old 15th April 2015, 06:07 PM   #12
thimios is online now thimios  Greece
or
Yes i can do it.I have done this many times.
I didn't bought a already programmed device.
Old 15th April 2015, 06:45 PM   #13
It seems that i have found something.
Old 15th April 2015, 07:11 PM   #14
sure,
you found the command line compiler for jalv2,
so you want to try that instead of what i suggested. okay
change/edit the compiler batch file to point to this install directory for the compiler and run in the directory where your source resides
or construct the command line accordingly
or in the gui set it up find the directory where the source file "_VV.jal" resides
> c:\jalpack\compiler\jalv2 -help
to get the command line options
>c:\jalpack\compiler\jalv2 c:\hi-end_pre-amp_dir\_VV.jal
Old 15th April 2015, 07:29 PM   #15
Code:
Compilation started at :4/15/2015 3:22:35 PM
jal jalv24q3 (compiled Sep 27 2014)
[Error] (f452_10.jal) [Line 2]  'pic_18f452' not found
[Error] (f452_10.jal) [Line 4]  unknown pragma target: osc
[Error] (f452_10.jal) [Line 4]  "osc" not defined
[Error] (f452_10.jal) [Line 4]  unexpected token: "osc"
[Error] (_VV.jal) [Line 26]  "disable_a_d_functions" not defined
[Error] (_VV.jal) [Line 26]  unexpected token: disable_a_d_functions
Compiler CommandLine:  C:\JALLIB~1\compiler\jalv2.exe "C:\Project\Hi-End PreAmp\SW\V1.1-test - Copy\_VV.jal" -s "C:\JALLIB~1\lib" -no-variable-reuse
Errors :6       Warnings :0
this is what you will get with jalv2. it is a different programming environment that is not backwards compatible with jal0459 as far as i can tell
Old 15th April 2015, 07:48 PM   #16
Is there any success?
I don't think so...
Old 15th April 2015, 08:31 PM   #17
okay i have my jal compiler environment up and going again,
what do you want printed in the start-up screen?
you have a two row x 16 character lcd display, it originally has
"Preamp v. 1.00 "
" Elektor 2004 "
Old 15th April 2015, 08:45 PM   #18
"Preamp v. 1.00 "
" Elektor 2004 "
"Preamp v. 1.00 "
"Tolis thimios"
Thanks for all your effort
Old 15th April 2015, 09:04 PM   #19
okay here you go
the file was originally named _vv.hex
so load it up, it should work.
Old 16th April 2015, 09:33 AM   #20
okay here you go
Thanks, i will try this in a new Pic18f452 just in case something is wrong.
Jal language helpHide this!Advertise here!
Universal language scott wurcer The Lounge 4 3rd December 2011 03:36 PM
The relationship between Language and Thought thadman The Lounge 69 10th May 2011 10:22 PM
lyrics-language question Juergen Knoop Music 3 23rd July 2007 12:21 PM
Language Help palesha Solid State 6 25th August 2002 03:51 PM
