Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Better power MOSFET models in LTSpice
Old 7th November 2017, 06:02 PM   #191
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by keantoken View Post
I've attached a demo file along with a symbol that will work with it. See if it work right for you.
Thanks Keantoken!
Hey, I just saw your Kuartlotron buffer - cool! Topology brought to mind the DLH amp/buffer I just played with. 4 actives and super low distortion. In case you haven't seen it. I will definitely try your K buffer though. I love 4 to 5 transistor circuits.
DLH Amplifier: The trilogy with PLH and JLH amps
Edit:
regarding your example schematic for the BSP129, what do I do with the txt file?
So I tried opening the .asc file and get an error missing symbol. How do I link the symbol txt file?
-Thanks.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 7th November 2017, 06:50 PM   #192
keantoken is offline keantoken  United States
keantoken's Avatar
Remove the .txt from the symbol file since the forum wouldn't let me upload a .asy file. If you keep it in the same directory with the .asc file I think LTSpice should find it and use it.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 7th November 2017, 07:09 PM   #193
Got Foam?
xrk971's Avatar
Keantoken, it works like a charm!
Super Thank you!
X
Old 8th November 2017, 03:44 AM   #194
IanHegglun is offline IanHegglun  Australia
Default LTspice Infineon subcircuit BSP129 plots
Thanks Keantoken, excellent work as usual
I'd like to know what type of MOSFET model Infineon use. Anyone recognise it?
Attached are some Vgs and Vds plots to check out the model. They plot two curves each. Stepped Tj non-electrothermal. OR you can plot a Fixed Tj plus an electrothermal. You choose which ones by changing the .Step commands: turn one off and the other on then re-Run. Some findings:
  • The Vds plot you can see subthreshold conduction is modelled and the threshold temp co is modelled.
  • The Vds-2V plots show entering saturation where there are abrupt changes in the slope just like LTspice vdmos. There is no drain conductance in saturation -- not sure if it is set to zero, or if it is not modelled. It's not obvious from the listings on how to set the drain conductance like Lambda does in the VDMOS. Anyone know how?
  • The Vds-50V sweep shows the drain conductance in saturation increases as Tj rises -- this is something that standard (isothermal) models do not give and at lower audio frequencies could easily change simulated distotion in many designs.
These seem to be excellent models. Obviously a lot of work has gone into developing them and making them available for a fairly wide range of simulators. The Introduction PDF Table 2.1 says the PSpice code ".lib" does SiMetrix, LT-Spice, and Multisim. Early documents are dated 2006.
Old 8th November 2017, 04:23 PM   #195
Bob Cordell is offline Bob Cordell  United States
The transition into the subthreshold region of conduction looks a little too sharp. Comments?
Bob
Old 8th November 2017, 04:26 PM   #196
keantoken's Avatar
That is reverse diode conduction, not subthreshold. It's actually a Id/Vd chart.
Old 8th November 2017, 05:53 PM   #197
Got Foam?
xrk971's Avatar
Hi Keantoken, just wanted to say Thank you again. Here is where the BSP129 model ended up at:
AKSA's Lender Preamp with 40Vpp Output
You should like it, a 4 BJT (not including the BSP129 as a CCS) preamp with gain and 40vpp muscle.
Old 7th January 2018, 11:27 AM   #198
astx is offline astx  Austria
Default IXYS IXTH80N20L and IXTH48P20P models by David Zan
Attached 2 models for the IXYS linear MOSFETs IXTH80N20L and IXTH48P20P created by David Zan.
Permission for distribution here: Fully Differential Amplifier With CMCL
The simulation of a class AB amplifier using these models was very successful verified in a real amplifier here 2stageEF high performance class AB power amp / 200W8R / 400W4R.
Code:
* David Zan, (c) 2017/03/02 Preliminary
.MODEL IXTH80N20L VDMOS Nchan Vds=200
+ VTO=4 KP=15
+ Lambda=2m
+ Mtriode=0.4
+ Ksubthres=150m
+ Rs=5m Rd=10m Rds=200e6
+ Cgdmax=9000p Cgdmin=300p A=0.25
+ Cgs=5500p Cjo=11000p
+ Is=10e-6 Rb=8m
+ BV=200 IBV=250e-6
+ NBV=4
+ TT=250e-9
.MODEL IXTH48P20P VDMOS Pchan Vds=200
+ VTO=-4 KP=10
+ Lambda=5m
+ Mtriode=0.3
+ Ksubthres=120m
+ Rs=10m Rd=20m Rds=200e6
+ Cgdmax=6000p Cgdmin=100p A=0.25
+ Cgs=5000p Cjo=9000p
+ Is=2e-6 Rb=20m
+ BV=200 IBV=250e-6
+ NBV=4
+ TT=260e-9
Hint: have a look at first post of my threads for an updated index!
Old 7th January 2018, 12:21 PM   #199
keantoken's Avatar
Cool.
Old 23rd May 2018, 11:56 AM   #200
haiqu is offline haiqu  Australia
haiqu's Avatar
Default VMOS
What's the closest model to the old Siliconix VMP series VMOS parts? I've acquired a quantity of them and want to start working with them, especially the Russian equivalents like the KP901A.
Examples also include the (renamed) 2N6656-2N6661 parts.
[VK9VK] With great power comes great current squared times resistance.
I spent most of my money on fast cars, hot girls, hi-fi gear and booze. The rest I just wasted.
Better power MOSFET models in LTSpiceHide this!Advertise here!
LTSpice tube models Osvaldo de Banfield Software Tools 27 26th October 2013 06:04 AM
LTSpice models needed popilin Tubes / Valves 6 25th April 2013 12:08 AM
Adding models in LTSpice danny92 Software Tools 1 13th April 2013 10:05 PM
Ltspice and Valve models Melon Head Software Tools 3 18th October 2009 08:35 AM
2SJ and 2SK Power Mosfet Spice Models Requested alaskanaudio Everything Else 4 14th December 2001 01:14 AM
