HOLM "time lock" help needed - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 17th November 2014, 11:45 PM   #1
Default HOLM "time lock" help needed
Hello folks,
I'm new to the forum. Hopefully when my knowledge increases I'll be able to join in on some the conversations around here. But for now all I have is questions.
I've recently learned ARTA and now I'm learning HOLM. I'm finding it fairly straightforward to learn but for some reason I'm stuck on the "time lock" feature. I need a step by step tutorial here as I'm just not getting it. I understand what the feature does just not the proper steps to using it properly.
Do I simply take my first measurement of the tweeter on-axis using measurement section A, then go to the Data analysis tab, click on "time lock" and "use", then go back to the measurement tab and measure the tweeter again and then measure the woofer in measurement section B? Should I use the tweeter and woofer measurements that were taken AFTER I clicked "time lock" and "use"?
Old 18th November 2014, 09:11 PM   #2
Hmm. I thought there were a number of HOLM users here that might be willing to help me out. Guess not.
Can anyone point me in the direction where I might find the answer? Thanks.
Old 19th November 2014, 02:17 PM   #3
JMB is offline JMB  United States
I do not use Holm but as I recall there was a discussion either here or at Partsexpress forum that described this feature. I think that you have to take a measurement and then set the lock feature so that all subsequent measures abide by it.
Old 19th November 2014, 03:33 PM   #4
Thank you. I've search and searched for that discussion but can't find it. I read through over 50 pages on this board last night and couldn't find the answer. And an extensive Google search has not helped either.
I believe you're correct about how to use it properly. I'd just like to be 100% sure before I commit to using Holm for real work. I PM'd John K. over at the parts express board with this question because he's mentioned in the past that he's very familiar with this software. Hopefully he'll have the answer for me soon. I'm getting my Cross Spectrum Labs mic this week and would love to put it to good use.
Thanks again.
Old 25th November 2014, 03:23 PM   #5
jtalden is offline jtalden  United States
> Device & Signal/Start Stream ("Keep in/out stream active" should be checked first).
> Measure a tweeter.
> Data Analysis/Time zero locked (select)
> Then select "last detected"/Use
The key you may be missing is probably the first step? It must be activated first.
The "locked offset" value can be set in other ways and the value can be change as needed to adjust the timing where you want it.
Schematic for AVI CD Player "S21MC" from "Labaratory Series" needed tiefbassuebertr Digital Source 0 3rd June 2012 09:46 PM
"REPLACE YOUR GUITAR AMP TUBES WITH THD "Yellow Jackets" NO REBIAS NEEDED. JUST PLUG cbdb Instruments and Amps 2 14th March 2012 06:49 PM
Has anyone used this "Heat Lock" to Iron-on veneer andy2 Multi-Way 3 23rd April 2011 04:05 PM
How do you connect a PLL "Lock" LED to the CS8416? G Digital Line Level 1 3rd March 2009 07:47 AM
"Signal Lock" Indicator for CS8412/TDA1543 Nisbeth Digital Source 7 5th January 2004 10:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
