Is it useful or rational to build a driver with a QTS between 0.9 and 1.1 in a Box with ports (could be a TL or TQWT)?
If the simulation with tools, such as the transmission line modelling tool, shows a reasonable frequency response, could it work or is this complete ********?
Using the TSP like the fs-qts-ratio of a driver can only be seen as a first approximation.
The following simulation doesn't tell you anything about the sound quality of the resulting box. If you have the opportunity design/simulate different chamber-types for your speaker and and choose for yourself if you prefer BR, TL, CB or OB.
A TL can be easily realized after the following calculation:
Transmissinonslinie- Berechnung "Intertechnik-Line" | Lautsprecherbau
For simulation of Chambers I use LASIP. It works very well IMHO!
Sure, but the biggest problem of drivers with a qts > 1 is the overdone bass, isn't it?
I really like transmission lines. But i hate OB ^^.
I think the transmission modelling tool from leonard audio is as good as lasip.
So is it possible to get a good speaker out of a transmission line with a driver which has a qts > 1?
Besides OB, the TL is the only way to get a quality bass from a high Qts loudspeaker. So yes, go for it!So is it possible to get a good speaker out of a transmission line with a driver which has a qts > 1?
If the driver has a high Qms (close to 10), so most of the Qts is determined by Qes, a BR might work. You will wind up with a large cabinet and a low tuning and it is not certain it will work, but it is worth a try.
For example, both these drivers work very well in a BR, in spite of high Qts (although not quite one, both drivers fall completely out of the recommended bandwith for BR, the reason is the ratio of Qes over Qms).
https://www.parts-express.com/aurasound-ns3-193-8a-3-extended-range-driver-8-ohm--296-258
https://www.parts-express.com/dayton-audio-nd105-8-4-aluminum-cone-midbass-driver-8-ohm--290-214
