eagle ERC check - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 8th October 2014, 09:36 PM   #1
kees52 is offline kees52  Netherlands
Default eagle ERC check
Hi There
I have seen that Eagle do sometimes not see when a pad/pads are not connected, I have two not connected but eagle say everthing was connected, this is not good, I do not trust eagle anymore for check connections, it may not happen..
Someone have this?
regards
Old 9th October 2014, 02:34 AM   #2
Vasquo is offline Vasquo  United States
One trick I do (as form of insurance and double checking), is to turn off all layers, just leaving the airwire layers on. -- then see if anything shows up.
Old 9th October 2014, 05:23 AM   #3
If you use the 'ratsnest' command, it will tell you how many airwires are left, and it will clean up redundant unrouted airwires between routed pads. Not sure why ERC/DRC wouldn't do that, but maybe it's some preference setting?
Old 9th October 2014, 11:58 AM   #4
This is what I did, but it do not make eagle trustable, special when complicated pcb are make.
So I think it can be a program error, or as you said preference settings, I go look about it.
regards
More Help with Eagle dmtparker Software Tools 4 30th September 2014 05:08 PM
Using Eagle carlmart Software Tools 9 26th July 2014 09:49 PM
Measurement method Check and X-over Check wilk1 Multi-Way 9 10th January 2013 11:22 AM
ERC Protel99 problem, please help! padamiecki Solid State 6 3rd December 2004 07:20 AM
eagle nickgreek Everything Else 0 6th November 2003 12:24 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
