testing virtual/real designs - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 12th September 2014, 07:29 AM   #1
Default testing virtual/real designs
I had some basic questions about the design and development process of any audio design. I plan to use ltspice to simulate, and then maybe breadboard it or use eagle and do a toner transfer pcb. So far I have just made other people designs and never did much of designing my self. I have worked on non audio designs though, led drivers, microcontrollers, non audio multichannel dacs, some digital circuits etc.
How do you test a design in ltspice. I have only used pulse to generate square waves so far for non audio work. I know it can do sine waves and 'raw waves' also. how do you capture the noise numbers etc.
Same thing with a real circuit also, I have an old tek scope, without the usb; and a square wave signal generator. What waveforms do you test with, what do you check on the scope to know the noise numbers are good enough etc.
Old 14th September 2014, 09:14 AM   #2
I think you're on the right path basically, but you just have to figure out what you're trying to do in order to know what you need to do. :-)
Yeah, that sounds silly, but I'm replying because I'm doing the "theory, LTSpice, Eagle, toner-transfer prototype, put it on the test gear" loop right now, and it is working out for me.
In my case, I'm breadboarding specific circuits to make sure that they behave the way that I think they should, and also to see if there are any unforeseen problems that could be addressed before I send a pile of CAD and components off to a PCB/assembly house to generate a pile of pricey landfill. In your case, maybe you just want to make some nice gear that does something useful for you, like a power amp or a headphone amp.
In that case, use the tools to whip up a prototype and maybe listen to it? I have a nice Audio Precision analyzer, so I can see in great detail what the thing is doing, but still, a series of listening tests might be able to discover much of the same information as you tweak the design. Of course, I too will listen to some of these circuits, but only after I know that the circuits work well enough to pass the simple measurements and tests.
What are those measurements? I like to measure distortion, but not as a percentage, but as a spectrum of the distortion analyzer residual. In this way, I can see what makes up that (for example) "0.05%" THD+N number… is it hum? broadband noise? and which harmonics are present and in what quantity? You need a distortion analyzer to do that, but you can probably take the analyzer residual of a simple analyzer and feed it into a PC/soundcard to take the FFT of it to see what it's made of. Or, get an AP2 test set.. ;-)
Your question about LTSpice: I usually use a .tran analysis to test a random circuit, since it can handle startup behavior as well as all sorts of funky problems that might not be visible with a simple 'frequency response' type test. Still, a simulation is only as good as the component models you feed it, and sometimes, it's tough to accurately model the entire design, including the PCB.
I end up using LTSpice to gain insight on how a circuit works, and to be able to mess with the component values and choices quickly and to see how they affect the circuit. I then try to whip up a simple prototype using real components and perhaps a "non-real" layout (i.e. a single sided toner-transfer PCB layout) just to see if reality follows the model.
I would not expect to judge performance on a 'scope, other than to see if the circuit is oscillating or otherwise misbehaving. Oscilloscopes are not meant to give you high precision measurements (unless you pay $$ for a modern digital scope) but they're very useful to tell you some basic information very quickly: is each part of the circuit behaving like I think it should? Is each stage running at the right DC operating point? Is the circuit oscillating because of a bad layout or poor component choices, or a design defect? Stuff like that…
Anyway, I'm rambling, but you're not far off, and all you need to do is dive in a little further and see what works for you.
Best regards!
Real DIY fun hybrid testing. kees52 Tubes / Valves 0 21st April 2012 01:31 PM
Virtual chokes bigwill Tubes / Valves 5 11th April 2009 04:27 PM
Audio Garage Sale (real not virtual) Timn8ter Swap Meet 16 1st September 2008 11:39 PM
virtual ground...help jsteigs Chip Amps 6 3rd February 2005 10:49 AM
Combing effects: How real in "real" rooms? smeade1079 Multi-Way 3 10th March 2003 12:32 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
