Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Help with Eagle
Help with Eagle
Old 8th September 2014, 02:43 PM   #1
dmtparker is offline dmtparker  Panama
Default Help with Eagle
I just downloaded the current (free) (Linux) version of Eagle and designed my first pcb. It took forever to get through all the ERC and DRC, but I made it. The schematic is perfect. The problem is the size of the various parts on the pcb, e.g. different capacitors. Their libraries have about a gazillion parts so probably the one I want is there somewhere, but is there an EASY way to find say a 1000uF/63V cap with a base diam of 22mm and pin spacing of 12mm? or a way to change the size/pin spacing of a more generic cap and save it as my own?
It seems like it should be an obvious need but I have reviewed several tutorials for Eagle without finding out ho to do this.
Old 8th September 2014, 05:15 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Help with Eagle
Depends a little on what symbol you have used, but one option is to select the "replace" tool and then navigate to the RCL library to find standard cap packages. Once you have the one you want, click the part that you want to change and it should change to the new package. Alternatively, go to "change" and select "package". Then click on your part and you will get a list of "compatible" parts that you can change to. Then find the one you want in the RCL library.
/U.
DIY projects blog
Old 8th September 2014, 05:28 PM   #3
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I use component names with part numbers.
e.g. C_P2_RS245-7809
This is a (C) capacitor with point 2 inch pitch and is Radio spares part number 245-7809
This name also gets sent through to the parts list and makes ordering parts much easier.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 14th September 2014, 03:17 PM   #4
kees52 is offline kees52  Netherlands
little old thread but usable for my question about eagle.
I have export cam inverted postscript but get a dark area left and under
the pcb drawn, this is not when do normal export see pictures.
maybe somewone now what it causes, it eats toner for nothing.
thanks
regards
kees
Old 14th September 2014, 03:46 PM   #5
thanks
regards
kees
I, too, am a newbee to Eagle, but I think your problem is one of two possibilities. First, when you go to "Print" uncheck the box that says "Black". Be sure to check the "Preview"and see if that solves the problem. If not, go back to your board and Choose "View>Layers" and choose a pale color for the top layer. For me, at least, that got rid of the black around the edges (which was a ground plane).
Hope this helps.
Old 14th September 2014, 04:49 PM   #6
I have found the problem, when I do offset chang from 0 inch to 1 inch in cam output job I get this problem.
and only with inverted output.
thanks,
kees
Help with EagleHide this!Advertise here!
Using Eagle carlmart Software Tools 9 26th July 2014 09:49 PM
eagle question PreSapian Software Tools 4 9th April 2014 10:06 PM
Eagle 6.4.0 bug? BrianVG Software Tools 2 23rd January 2014 09:40 PM
Eagle 6 now available!!! GLooP Software Tools 5 18th January 2013 05:48 PM
eagle nickgreek Everything Else 0 6th November 2003 12:24 PM
