Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Installing and using LTspice IV (now including LTXVII). From beginner to advanced.
Old 2nd January 2018, 11:49 AM   #941
FdW is offline FdW  Netherlands
FdW's Avatar
Actually the 2700fish should equal 2700FemptoIsh (some really small Ish'es )
Urban Dictionary: ish
Old 2nd January 2018, 11:57 AM   #942
Mooly's Avatar
Lol, yes.
Is this fish dead, 'cos I think its eaten half my chips
Old 6th January 2018, 06:54 PM   #943
kees52 is offline kees52  Netherlands
I have a problem with ltspice so I ask you guys as the professionals why it did not work, connections problem, hoever with import model the same problem.
Thanks in avance.
kees
Old 6th January 2018, 07:49 PM   #944
djoffe is offline djoffe  United States
Default issue was pin/net list number problems
I've enclosed the files where the symbol is corrected. Just replace your old .asy with this one.
it will say opa1612.txt, but just rename it to opa1612.asy and replace the old .asy file.
File Type: txt OPA1612.txt (796 Bytes, 7 views)
www.akitika.com Featuring the GT-102 Power Amp and PR-101 Preamp kits
www.updatemydynaco.com Featuring upgrades for classic Dynaco Solid State Equipment
Old 7th January 2018, 01:13 PM   #945
Hmmm thanks a lot, What did I wrong? because some of the two has more pins LTspice say.
thanks again for your help.
kees
Old 7th January 2018, 01:33 PM   #946
Unfortunately it does not work, I get much offset and no amplifing of the signal.
In the model the numbers are different then in the symbol did try of adjust but no succes. just look at the lib file, it is a dual opamp original OPA1622 but I use it as a single one, maybe there is the problem.
regards
kees
Old 7th January 2018, 02:06 PM   #947
Default Try this...
I've zipped it up, and included a test bench in which it looks ok. Unzip this all into a virgin directory, and then run the .asc file. See if that works for you.
Old 7th January 2018, 02:34 PM   #948
mr2racer is offline mr2racer  United States
mr2racer's Avatar
Hey All, I hope I'm on the correct thread this time? I'm using LT Spice XVII so that may be a problem for this thread? I've attached a screen capture from Spice. I managed to get the model into Spice but it is in the Auto Generated folder. I need to know how to attach the triode symbol to it and how to move it to the triode-w1.dd.
Artificial intelligence is no match for natural stupidity- Red Green
Old 7th January 2018, 05:15 PM   #949
Did not work, I get no output signal and uge offset.
the Lib file has very different ports, you did use 1,2,3,4,5 lib is 3, 2, 7, 3, 6
Do not understand it works for you.
Last picture you see ltspice do work normal with that class d.
regards
Old 7th January 2018, 05:20 PM   #950
Mooly's Avatar
I had a play with this last night and got nowhere, and another try today and the same (in LTXVII).
Just tried djoffe's file and it ran straight off.
I have to admit I struggle with models... I should put more effort into this but you know what its like
Installing and using LTspice IV (now including LTXVII). From beginner to advanced.Hide this!Advertise here!
[LTSpice] Beginner - help with capacitor multiplier? bugbear Power Supplies 17 11th November 2016 11:18 PM
Meistersinger VFA-200, A beginnerís first try in LTSpice nattawa Solid State 34 29th January 2016 01:58 PM
Including a C- winding on a filament transformer AllenB Tubes / Valves 2 8th May 2014 05:17 AM
Need help installing LTSpice rif Software Tools 4 30th May 2013 01:59 AM
