Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Installing and using LTspice IV. From beginner to advanced.
Old 25th November 2017, 07:53 PM   #861
keantoken is offline keantoken  United States
keantoken's Avatar
Subcircuit not found. That means the symbol is there on the schematic, but LTspice can't find the .sub file somewhere that contains the actual electrical model that goes with the symbol. You need to put the .sub file in the same folder as the schematic and use the .inc command on the schematic to tell the simulator to use it.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 26th November 2017, 03:39 AM   #862
george_ct is offline george_ct  Romania
@Mooly
The link for WIKI from the first page (first message) does't work anymore. The link that must be inserted is this one:
http://www.diyaudio.com/wiki/Special...s?userid=52623
Also the link from this phrase (from the first page, first message) does't work anymore:
A/ Using LTSpice simulation command for a DC sweep for resistors. For a worked example see post # 560 ........ (submitted by pr)
The correct link is this one: Installing and using LTspice IV. From beginner to advanced.
And also the link from this phrase (from the first page, first message) does't work anymore:
B/ Functional LF198/LF298/LF398 Sample and Hold, post #754 .......... (submitted by FdW)
Old 26th November 2017, 09:18 AM   #863
Mooly's Avatar
Thanks for pointing these out George Links have become a bit of a major issue lately with recent forum changes. Of the original links you mention, the Wiki doesn't work for me but the other two do ! and for your replacements the Wiki works and the other don't. Those last two return me to post #861 just above these. Arghhh.
I'll see what we can sort out (jazbo is good on these, hint hint)
Old 26th November 2017, 09:55 AM   #864
Mooly's Avatar
jazbo has worked his magic on these links.
Old 4th December 2017, 07:48 AM   #865
Straight Tracker is offline Straight Tracker  United States
Default Thank you for your precious time
Hello Mooly,
A kind gentleman on the Internet provided me with a servo circuit for my tangentially tracking tone arm. The circuit works perfectly, but I don't understand how it works. A few days ago I downloaded LTspice and I would like to know if I can/may download your entire thread so that I can take it to my work station and go through your tutorials in the peace and quiet of my shop.
Sincerely,
Ralf
Old 4th December 2017, 08:06 AM   #866
jazbo8 is offline jazbo8
jazbo8's Avatar
Please see: Can a (long) thread be downloaded?
Old 5th December 2017, 12:26 PM   #867
martyh is offline martyh  United States
Is setting up the dc supply as ac with an offset a valid way to check PSRR? I.E. I set up a 1 volt peak 100 Hz ac source with a 350V dc offset to power a tube circuit. Ran the simulation with a 0v ac input and looked at the output.
Old 5th December 2017, 12:58 PM   #868
Mooly's Avatar
For checking PSRR you really need to either simulate an appropriate shaped ripple voltage or you can even use an AC source feeding a rectifier.
Here are typical settings to generate a ripply rail.
Old 6th December 2017, 12:18 AM   #869
Thanks again Mooly
Old 21st December 2017, 01:08 PM   #870
kees52 is offline kees52  Netherlands
some question for the LTspice specialists here.
Why I get such a bad drive signal for the lower fet?, it looks not very good, I get the deadtime not right that way
Maybe @analog do now because he did make them.
kees
Installing and using LTspice IV. From beginner to advanced.Hide this!Advertise here!
Meistersinger VFA-200, A beginnerís first try in LTSpice nattawa Solid State 34 29th January 2016 02:58 PM
Need help installing LTSpice rif Software Tools 4 30th May 2013 02:59 AM
installing sub without rca ibanez Car Audio 7 15th May 2007 12:58 PM
installing volume sarahlove Parts 6 16th May 2006 04:10 PM
More advanced marketplace peranders Swap Meet 0 14th August 2002 09:03 AM
