Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Installing and using LTspice IV. From beginner to advanced.
Old 10th October 2017, 02:54 PM   #841
FdW is offline FdW  Netherlands
FdW's Avatar
And one more
Old 13th October 2017, 01:54 PM   #842
mr2racer is online now mr2racer  United States
mr2racer's Avatar
Hello!
Artificial intelligence is no match for natural stupidity- Red Green
Old 26th October 2017, 09:30 AM   #843
jazbo8 is offline jazbo8
jazbo8's Avatar
Is there a way to display sub grid lines for the Y-axis when using the Log scale?
Old 26th October 2017, 10:30 AM   #844
Mooly's Avatar
You know more than me on all this
In what context do you mean ? What view do you want grid lines to display on.
Old 26th October 2017, 10:56 AM   #845
jazbo8's Avatar
It's something so simple, but why is the tick gray out for the Y-axis log scale?!
File Type: jpg Screenshot - 10_26_2017 , 11_54_27 AM.jpg (554.0 KB, 113 views)
Old 26th October 2017, 11:18 AM   #846
martyh is offline martyh  United States
Originally Posted by FdW View Post
And one more
Not sure how I missed your posts before this morning but thank you for the help. Very cool stuff
Old 26th October 2017, 12:13 PM   #847
Mooly's Avatar
Dunno on that one. It is the same in LTXVII, greyed out.
'Tick' is the scaling isn't it ? so log scaling isn't a constant increment like 10, 20, 30 etc, if that makes sense.
Old 26th October 2017, 12:34 PM   #848
jazbo8's Avatar
The spacing on the log scale isn't constant, but surely the software can figure it out, since the X-axis ticks work just fine. Must be a "feature" of LTSpice.
Old 26th October 2017, 03:01 PM   #849
Mooly's Avatar
X axis is greyed out for me when selecting log (last image). I can't see how you could enter a setting for 'log' because ech increment goes up by a power of ten. You can set the upper and lower limits though.
Some of the other settings seem a bit odd, as if it doesn't like some values
Old 13th November 2017, 01:31 PM   #850
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default Node 0 in subcircuit converted?
Almost all subcircuits have an internal node 0 as the 'ground' node for that particular circuit.
But what happens when you use for instance an opamp that floats with Vcc=200V and Vee=170V? In real world that would work fine (assuming the input/output signal common mode is respected).
I had some problems with such a circuit in my previous sim as it kept some internal subcircuit bias R's and generators referred to gnd which now is 170+V away of course.
In LTspice is seems to work, so I wonder is LTspice *somehow* modifies the internal node 0 to *some* circuit node that can float with power supply?
Anyone knows about this?
Jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Installing and using LTspice IV. From beginner to advanced.Hide this!Advertise here!
Meistersinger VFA-200, A beginnerís first try in LTSpice nattawa Solid State 34 29th January 2016 02:58 PM
Need help installing LTSpice rif Software Tools 4 30th May 2013 02:59 AM
installing sub without rca ibanez Car Audio 7 15th May 2007 12:58 PM
installing volume sarahlove Parts 6 16th May 2006 04:10 PM
More advanced marketplace peranders Swap Meet 0 14th August 2002 09:03 AM
Copyright ©1999-2017 diyAudio
