Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
XSim free crossover designer
Old 29th November 2017, 06:29 PM   #391
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Thank you so much
RC
Old 29th November 2017, 06:31 PM   #392
Pano is offline Pano  United States
Pano's Avatar
You can use ARTA, HOLMImpulse or REW among other to give you the FRD files you want. Don't forget the impedance files! ZMA
Take the Speaker Voltage Test!
Old 29th November 2017, 06:34 PM   #393
nhinstruments
RCruz's Avatar
Thank you again
RC
Old 29th November 2017, 06:35 PM   #394
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Yup (but don't forget Omnimic too!). Easiest way to measure for ZMA file is the DATS or a Woofer Tester.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 29th November 2017, 06:40 PM   #395
Pano's Avatar
Yes indeed! Sorry for omitting Omnimic!
Old 30th November 2017, 11:56 PM   #396
joetekubi is offline joetekubi  United States
Originally Posted by bwaslo View Post
That's not supported now, but you could instead shift the dB level of the simulated response (for comparing to the FRD file curve display) by simply Tuning the power level on the Power Amp symbol!
How are you printing? Grid dots shouldn't be there (I don't see them when I print here)?
Maybe try this: File -> Snapshot -> To Picture File -> As Shown, then save as type .png
Open the png file in PaintBrush (or other graphics app) and print from there. Should be crisp and clear, no dots or smearing. (you could also save as a .pdf file, to be even more clear, but then you have to load Adobe to print).
or: File -> Snapshot -> To Windows Clipboard -> As vector graphic; and then paste it into your graphics app (such as Clipboard)
I'm running on Ubuntu using the PlayOnLinux utility.
XSim itself runs very well - I suspect that the printout function is messed up somewhere between PlayOnLinux apis and Linux. Please don't worry about it.
Not a biggie for me.
Old 30th November 2017, 11:59 PM   #397
@Bill -
Thanks for the measurement and sim writeup!
Very clearly explained. Should be a sticky somewhere!
Old 15th December 2017, 05:27 PM   #398
bwaslo's Avatar
There's a new update of Xsim now up -- http://libinst.com/Xsim/XSimSetup.exe
Mostly some bug fixes, a few new things -- derive a driver's impedance phase from only the magnitude of a ZMA file (so you could just make a curve from points read off a manufacturer's data sheet) The "file" curve in the Frequency Response phase can now be offset up or down with a dB offset scale control. Curve colors changed a bit for better visibility. Some hint bubbles pop up to show new users how to do some non-obvious functions (the hints can be turned off).
Note: Xsim has (even before the update) an "auto-updater", which I found out is HATED by the antivirus program Avast! Apparently Xsim's wanting to go out on the net to download the update gives Avast a scare. You might have to turn off your antivirus program for a few minutes to let it complete if your current install of Xsim tries to do its own update and your antivirus is particularly intrusive.
Old 15th December 2017, 05:32 PM   #399
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Magic, update downloaded. Many thanks for all the effort you continue to put in, Bill
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 15th December 2017, 05:54 PM   #400
rickmcinnis is offline rickmcinnis  United States
Just in time for Christmas!
This is truly a gift that keeps on giving. Such a great tool.
THANKS very much!
Rick McInnis
XSim free crossover designerHide this!Advertise here!
Update to Windows Passive Crossover Designer available dlr Software Tools 1 15th May 2014 10:46 PM
Windows Passive Crossover Designer v1.2 available for download dlr Software Tools 15 13th December 2013 11:48 PM
Active Crossover Designer version 2 released CharlieLaub Software Tools 1 12th November 2012 09:08 PM
Orcad/AutoTRAX EDA - free schematic capture/PCB designer Ilija Everything Else 3 16th July 2003 11:11 AM
