EDA Package - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 19th May 2014, 07:58 AM   #1
knutn is offline knutn  Norway
Default EDA Package
Has someone used EasyEDA - Web-Based EDA, schematic capture, spice circuit simulation and PCB layout Online?
Old 19th May 2014, 09:19 AM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Yes, I am using it for schematic capture. Eventually I'll get on to PCB design.
When irony first makes itself known in a young man's life, it can be like his first experience of getting drunk - Robertson Davies
Old 19th May 2014, 03:37 PM   #3
They also have the possibility to make PCBs (but at which quality?)
And the simulator seems to be similar to LTSpice.
Old 19th May 2014, 11:41 PM   #4
abraxalito's Avatar
I've heard their PCBs are very cheap - the guy who'se programmed a lot of the code for this I know quite well and a couple of years ago he sent me some PCBs when he was testing out the site. The quality seemed fine but of course I don't know that he's still using the same manufacturer.
The simulator is indeed very similar to LTSpice - that's intentional so all your existing LTSpice sims can be uploaded and hopefully still run.
Old 20th May 2014, 12:37 AM   #5
kevinkr's Avatar
Surprisingly easy to use schematic capture tool. Good basic libraries. I'm going to check this out further.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 21st May 2014, 08:03 AM   #6
Yes, it should be interesting to use the schematic, simulator and pcb package for a new project.
Old 22nd May 2014, 03:35 PM   #7
It's great to see so much interest in EasyEDA here and in particular using it for simulation, so I thought it might help to explain a little about the simulator used in EasyEDA.
EasyEDA uses the Free and Open Source Software Spice (FOSS) ngspice simulator.
Whilst EasyEDA is able to directly import flat LTspice .asc schematics - and they look just like they do in LTspice - there are some things you need to be aware of and to check to successfully run them in EasyEDA.
For a quick explanation it's best to have a look at the Import LTspice section of the EasyEDA tutorial here:
Import LTspice -- EasyEDA tutorial
(BTW: since writing that section, a LIMIT function has now been made for ngspice so that it works the same way as in LTspice)
It is possible but a bit clunky to import hierarchical LTspice schematics into EasyEDA and there are also some things that are hard to do or don't yet work but for a lot of simulation work it is fine.
If you need some of the advanced features and models that LTspice offers then there's no reason not to run the sims in LTspice and then import the schematics into EasyEDA when you need to expand them into full schematics ready for PCB layout.
It is also possible to download spice netlists from EasyEDA and run them directly in LTspice (noting things like the different syntax for raising to a power: ^ in ngspice and ** in LTspice; and the log10 and natural log functions).
For help getting sims to run in EasyEDA, have a look at:
Spice tutorials
Spice simulation skills
Making measurements
or contact support@easyeda.com
Copy of Kore-Eda pre ? sinski Chip Amps 2 4th May 2006 12:03 PM
Better transistor package? JojoD818 Solid State 41 17th July 2003 11:32 PM
Orcad/AutoTRAX EDA - free schematic capture/PCB designer Ilija Everything Else 3 16th July 2003 11:11 AM
complete package spyder Swap Meet 1 11th September 2002 12:43 PM
Users newsgroup for AutoTRAX EDA Ilija Everything Else 0 22nd July 2002 07:42 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
