Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Standard, platform independent simulations for DIYAudio
Old 28th February 2014, 12:21 PM   #51
spookydd is offline spookydd  France
Originally Posted by keantoken View Post
You'll have to ask Mike about it like I suggested. Does kean.bjt appear in the schematic directory?
I emailed to linear, I guess that generic address goes to mike. On the mac there is no "about" option under the help menu, it's somewhere else, but I found it and got that address. We'll see if something is done to fix this.
I forgot to mention earlier, but I only get the error and no file gets downloaded anywhere.
Now I have one other question: How do we simulate darlingtons?
I dug out some old models from what I saved over time, let's see if this is usable:
.SUBCKT tip142 1 2 3
* Model generated on Feb 8, 2004
* Model format: SPICE3
* Darlington macro model
* External node designations
* Node 1 -> Collect
* Node 2 -> Base
* Node 3 -> Emitter
Q1 1 2 4 qmodel
Q2 1 4 3 q1model area=19.6725
D1 3 1 dmodel
R1 2 4 8000
R2 4 3 40
* Default values used in dmodel
* EG=1.11 TT=0 BV=infinite
.MODEL dmodel d
+IS=1e-12 RS=10 N=1 XTI=3
+CJO=0 VJ=0.75 M=0.33 FC=0.5
.MODEL qmodel npn
+IS=2.92836e-16 BF=233.76 NF=1.2 VAF=1000
+IKF=0.222129 ISE=4.61322e-11 NE=2.48158 BR=1.89854
+NR=0.75 VAR=168.458 IKR=0.108495 ISC=9.99999e-14
+NC=2.00001 RB=7.90758 IRB=0.2 RBM=7.90758
+RE=0.275456 RC=1.42279 XTB=0.232595 XTI=3.02293 EG=1.206
+CJE=1e-11 VJE=0.75 MJE=0.33 TF=1e-09
+XTF=1 VTF=10 ITF=0.01 CJC=1.67157e-09
+VJC=0.95 MJC=0.23 XCJC=0.9 FC=0.5
+TR=1e-07 PTF=0 KF=0 AF=1
.MODEL q1model npn
+XTF=1 VTF=10 ITF=0.01 CJC=0
.ENDS
Old 1st March 2014, 12:18 AM   #52
keantoken is offline keantoken  United States
keantoken's Avatar
It probably has the same pinout of the standard transistor symbol. On Windows, you would CTRL->Rclick on the transistor symbol, set the prefix to X and then give the transistor the name of your subcircuit. I can't say how to do this on Mac.
But, there is probably a more topical thread for that...
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 1st March 2014, 01:27 AM   #53
gannaji is offline gannaji  India
gannaji's Avatar
Originally Posted by keantoken Click the image to open in full size.
First, see if you can download the file in your browser using this:
http://startfetch.com/keantoken/ltspice/kean4.bjt
If not, then it is a problem with the server or with your network. If you can download the file, then it's a problem with LTSpice. If you go to Help->About, it will give you Mike's email address and you can send him a report.
Today, when I clicked on it, kean4.bjt is getting downloaded directly.
--gannaji
www.samritatrust.org
Teach me the glorious lesson that occasionally, I might be mistaken. Keep me reasonably sweet.
Old 1st March 2014, 02:33 AM   #54
keantoken's Avatar
Yes, the server configuration changed. You can try the simulator directive again to see if it works.
Old 1st March 2014, 07:11 PM   #55
Seems this won't be possible on mac, at least until that version gets more completed. There are so many things missing on the mac version, it's not easy sometimes to do certain things.
That option to right click on a part doesn't have the same effect on mac, and there is nothing to go change that QN or QP into an X, so I'm stuck with that.
Old 1st March 2014, 11:15 PM   #56
keantoken's Avatar
You can open the symbol manually, edit->attributes to set it to X, then save it as a new symbol.
Old 1st March 2014, 11:39 PM   #57
That's the problem, there is no way to edit attributes on the mac version, so there is no access to the attributes or anything else that way. Only the main libraries show up and we can't change to anything else.
I tried it on windows and the menu comes up and I did it there. Once the changes have been made and I go back to the mac to open that sim, then it does work.
That missing feature on the mac version is far from the only one. There is an other that I am really missing badly. Just like accessing the attributes of parts, we can't touch the data labels either. For example if I want a data label to display a current, or a power (from a calculation), then it can't be done.
An other missing thing is that when on windows we hover over some part to get that thermometer and get a power dissipation, that too doesn't work... And it goes on...
Old 2nd March 2014, 12:01 AM   #58
keantoken's Avatar
Wow, that's pretty bad. I would go to the Yahoo group about this one; it's probably already been asked.
Well, barring cometary intervention, you could manually edit the symbol files in a text editor, but I would only be guessing how to do that (may be fairly straightforward).
Old 2nd March 2014, 12:24 AM   #59
Editing the symbol files doesn't help much. I need to be able to insert something into a simulation and make changes. This is the hard part. Once it's in there, then as long as we don't need to edit attributes or change something else, it works.
I've figured out a few things that I do outside of ltspice, to compensate for some of those shortcomings, so I can do sims. Some manual editing of the actual text files sometimes, some done briefly on a windows ltspice install when all else fails.
I can't add (or change/edit) data labels for currents and power or other calculated values on the mac version, so I do that quickly on windows and go back to mac. A real pain, but it gets me by for now.
I wish I could get those dissipation readings and the likes as well, those don't work. Amazingly when hovering over a part, while holding shift, we can see sometimes the cursor changing to the thermometer, even with a small tooltip saying things, but all we can do is plot something, not make data labels.
Since I've been digging into those raw files directly with a text editor, I know a tiny bit more about them and I can edit a few things that way, and then it helps later in ltspice...
Old 2nd March 2014, 12:26 AM   #60
By the way, we're not limited to just transistors for the sharing of models. We can also share other types, such as opamps, opto, etc...
I'm trying to figure out how to use a model from TI of the ne5534, but so far no luck.
Standard, platform independent simulations for DIYAudioHide this!Advertise here!
Voltage independent power load egberttheone Power Supplies 15 23rd February 2012 05:44 PM
Parallel woofers - independent filter? Aleph 5 Multi-Way 18 16th August 2011 02:57 PM
Foam or rubber, environment independent? buggsson Car Audio 3 10th December 2008 12:06 AM
Independent (floating) supplies akis Power Supplies 15 7th September 2008 12:25 PM
Independent Bias Adjust for Each Tube? TubeHead Johnny Tubes / Valves 4 24th February 2008 12:57 PM
