Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Spint Layout into Gerber
Old 16th October 2013, 10:47 AM   #1
audiostrat is offline audiostrat  Greece
Default Spint Layout into Gerber
I am designing a pcb using Spint Layout. But since I want to order my pcb's from Seeed, they need gerber files.
I know there is a gerber export option in Sprint Layout, but can't find how to create the particular files Seeed wants - GTL, GBL etc.
Can anyone help?
Old 16th October 2013, 11:00 AM   #2
Groundloops is online now Groundloops
Im amazed!
Groundloops's Avatar
Top layer: pcbname.GTL (K1 - Copper top)
Bottom layer: pcbname.GBL (K2 - Copper bottom, NOT mirrored)
Solder Stop Mask top: pcbname.GTS (Soldermask top)
Solder Stop Mask Bottom: pcbname.GBS (Soldermask bottom)
Silk Top: pcbname.GTO (B1 - Silkscreen top)
Silk Bottom: pcbname.GBO (B2 - Silkscreen bottom)
NC Drill: pcbname.TXT (Drill data)
Then you simply can rename the files.
Old 16th October 2013, 11:19 AM   #3
So, for each layer that I have created with Sprint, I just export it to Gerber file and then rename it, right?
And, what am I supposed to do about that drill data?
Old 16th October 2013, 11:21 AM   #4
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
The GTL and GBL etc extensions they ask for are just their naming convention, so you just need to rename the Gerber file output from Sprint-Layout to match their requirements.
Email them if you are not sure which drill options in Sprint-Layout to use. I usually use 3.2 metric, but that's with other PCB fabs.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 16th October 2013, 11:27 AM   #5
Thank you!
I see. These drill options have to do with standard holes that they will have to drill? I mean, the holes I will specify in my files should be a standard size chozen over a certain known range? Is this what this means?
Old 16th October 2013, 08:18 PM   #6
Did it Himself
It's not that, it's the format the NC drill info is written in, the way the XY coordinates are written in the file.
PCB fabs will have a range of drills so there shouldn't be a problem. The only thing that might come up is specifying metric drill sizes and sending the Gerber to a fab house in the USA where often imperial sizes are more common. That said, even they are starting to use metric a lot nowadays.
Old 17th October 2013, 03:16 PM   #7
Thanks for the answer! I also use mm.
And how do I get this information out of Spint Layout?
Old 18th October 2013, 05:22 PM   #8
Did it Himself
File > Export > Gerber export.
Old 18th October 2013, 06:49 PM   #9
Oh sorry, I was talking about the drill information, I know about Gerber export.
How do I make it into the text form wanted?
Old 9th December 2013, 02:27 PM   #10
So I would like to order some pcb's from seeed, and I am a bit confused about how I should order a single copper layer pcb.
My options are:
Solder side (bottom) consists of : copper layer, soldermask + silkscreen, and:
(1) Component side (top) has only silkscreen.
(2) Component side (top) has through hole pads that come from the solder side (but no copper tracks), soldermask + silkscreen.
So, how do I implement the 2 options? Seeed asks for every layer (so how could I specify that I need no soldermask and copper, for case 1?). For option 2, I assume I just have to choose the option saying "through pad" for pads. Correct?
Spint Layout into GerberHide this!Advertise here!
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 11 12th January 2014 09:01 PM
Gerber file help!!!!!!! bullpeters Tubes / Valves 15 23rd March 2013 12:56 PM
Why a Gerber Viewer? jackinnj Solid State 17 9th February 2012 05:42 PM
PCB Layout & Gerber Generation for Mac OSX electronaut Parts 21 27th June 2007 05:19 PM
Gerber files for my Aleph pcb layout BrianGT Pass Labs 2 19th April 2002 02:16 PM
Copyright ©1999-2017 diyAudio
