Hi everyone,
Does anyone has the LM741/uA741 LTSpice models?
I need this models to do a school work.
Best regards,
Daniel
It is very easy
LTspice->Examples->Educational->LM741.asc
nobody makes them that poor anymore
nearly all spice op amp models are macromodels - use idealized controlled sources to aproximate the behavior of a given op amp
so you need to know what detail is needed and determine if available models work
in the simplest case you can use "universal" op amp models where you can set a few basic op amp parameters like DC gain, GBW, Slew rate
in LTspice the UniversalOpamp2 is included in
C:\Program Files (x86)\LTC\LTspiceIV\examples\Educational folder
This demonstrates the use of the symbol UniversalOpamp2(improved version to the UniversalOpamp). You set the SpiceModel to be
higher to simulate more aspects of opamp behavior. Level1 is merely a transconductance working into an R||C and doesn't use power
from the supplies. Level2 adds slewrate, current and voltage limits. Level3a adds a second pole. Level3b adds a delay to the dominate
pole response. Noise is modeled at all levels.
Here is a discrete uA741 model from:
Microelectronic Circuits
Sedra & Smith
5th Edition
* Model for uA741 Op Amp (from EVAL library in PSpice)
* connections: non-inverting input
* | inverting input
* | | positive power supply
* | | | negative power supply
* | | | | output
.subckt uA741 1 2 3 4 5
c1 11 12 8.661E-12
c2 6 7 30.00E-12
dc 5 53 dy
de 54 5 dy
dlp 90 91 dx
dln 92 90 dx
dp 4 3 dx
egnd 99 0 poly(2),(3,0),(4,0) 0 .5 .5
fb 7 99 poly(5) vb vc ve vlp vln 0 10.61E6 -1E3 1E3 10E6 -10E6
ga 6 0 11 12 188.5E-6
gcm 0 6 10 99 5.961E-9
iee 10 4 dc 15.16E-6
hlim 90 0 vlim 1K
q1 11 2 13 qx
q2 12 1 14 qx
r2 6 9 100.0E3
rc1 3 11 5.305E3
rc2 3 12 5.305E3
re1 13 10 1.836E3
re2 14 10 1.836E3
ree 10 99 13.19E6
ro1 8 5 50
ro2 7 99 100
rp 3 4 18.16E3
vb 9 0 dc 0
vc 3 53 dc 1
ve 54 4 dc 1
vlim 7 8 dc 0
vlp 91 0 dc 40
vln 0 92 dc 40
.model dx D(Is=800.0E-18 Rs=1)
.model dy D(Is=800.00E-18 Rs=1m Cjo=10p)
.model qx NPN(Is=800.0E-18 Bf=93.75)
.ends
Sedra & Smith
5th Edition
* | inverting input
* | | | | output
c1 11 12 8.661E-12
c2 6 7 30.00E-12
dc 5 53 dy
de 54 5 dy
dlp 90 91 dx
dln 92 90 dx
dp 4 3 dx
hlim 90 0 vlim 1K
q1 11 2 13 qx
q2 12 1 14 qx
r2 6 9 100.0E3
rc1 3 11 5.305E3
rc2 3 12 5.305E3
re1 13 10 1.836E3
re2 14 10 1.836E3
ree 10 99 13.19E6
ro1 8 5 50
ro2 7 99 100
rp 3 4 18.16E3
vb 9 0 dc 0
vc 3 53 dc 1
ve 54 4 dc 1
vlim 7 8 dc 0
vlp 91 0 dc 40
vln 0 92 dc 40
.ends
Hi everyone,
Thank you all for your help
Yes that's right in C:\Program Files (x86)\LTC\LTspiceIV\examples\Educational\LM741.asc directory, there is a circuit diagram of the internals of the LM741 (this circuit is good to better understand opamp topologies). I'm going to use jazbo's model. I'm doing a low power class C/B amplifier using the LM741 and BD139/140 pair it's a college work.
Best regards,
Daniel
Best regards,
Daniel
- Design & Build
- Software Tools
- 741 LTSpice model
