Pentode SPICE - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 4th October 2013, 07:44 PM   #11
jazbo8's Avatar
Would you have the triode-connected curve for the 6AC7? I can try to build a model with them.
Old 4th October 2013, 08:15 PM   #12
jazbo8's Avatar
Default 6LU8 with Ayumi's pctube
Here is Ayumi's 6LU8 model vs. the datasheet. Ayumi's model building process is described here. The key is not to use the Koren parameters...
Old 5th October 2013, 03:09 PM   #13
jazbo8's Avatar
Here is the Ayumi 6AC7 model vs. the datasheet, while the knees do not match up well, the transfer characteristic is spot on, so it should still be good for voltage amplifier applications.
Old 5th October 2013, 03:17 PM   #14
jackinnj's Avatar
Mind translating that into English? The useful portion of the pentode curve is >50V
Old 5th October 2013, 04:12 PM   #15
jazbo8's Avatar
Translate what?
Old 6th October 2013, 07:40 PM   #16
jackinnj's Avatar
The Ayumi text is in Japanese.
Old 7th October 2013, 08:44 AM   #17
jazbo8's Avatar
I used Google Translate to get through it, a lot of the text are math anyway, so you should have no difficultly understand them. But basically, Ayumi's model building process relies on electrical equivalent circuits, KCL and Child-Langmuir law unlike Koren's phenomenological approach. Ayumi's pctube program also uses a curve fitting technique similar to what you are doing with the Excel Solver routine.
Old 9th January 2014, 08:08 AM   #18
Alain Poitras's Avatar
Hi jazbo8,
I always use the Bing Translator
This translator give good results but it is for the math I need a translator ...
Old 9th January 2014, 09:11 AM   #19
This is the kind of accurate curves I like to have for every pentode or "beam power" tubes. I am not a math crack and I never try making a tube spice model by myself but I think this site will help me to understand how to do it.
This page explain the equivalent circuit of a triode and a pentode :
ayumi.cava.jp/audio/pctube/node47.html#SECTION00952000000000000000 - Translator
This is nice but I wonder if it is possible to get all the necessary data for the formulas only from the datasheet specifications and curves ?
I think the first step for a beginner like me to understand how the tubes models works is experimenting with fictive models and test tube data, just to see what kind of curves they produce. I also need to know more about the "URAMP" function because it is used almost everywhere ...
I think the pentode curves should be very accurate in the upper left where is the 0V knee and the lower right because this is where the tube is really operating in a power amplifier circuit, where pass the AC load line.
Thank you for this link !
Old 9th January 2014, 10:34 AM   #20
jazbo8's Avatar
The data usually comes from the datasheet, but sometimes, the data comes from traced curves from actual tubes, the formulas then try to describe in mathematical terms how to best describe the tubes' properties (not always successful though).
You are being too modest, you are not a beginner uramp(x) = x if x > 0, else 0. I'm not sure if SIMetrix uses it though, in any case, the Ayumi pctube library contains all the models in SIMetrix .MOD format, so you can use them directly.
That's actually the hardest part - around the knees, as shown by Robert in this post.
Great to see you back on the forum!
My attempt: 5 element Pentode Spice model aletheian Tubes / Valves 8 30th September 2013 02:19 AM
EF86 spice model is tetrode or pentode? Joseph R Software Tools 4 20th February 2010 09:00 PM
Free Spice Or Cheap Spice Simulator-Where To Start? kelticwizard Everything Else 29 15th February 2007 02:38 AM
Spice 3f4 model of a low voltage direct heated signal level pentode wa2ise Tubes / Valves 0 24th April 2006 01:18 AM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 06:16 AM
Copyright 1999-2017 diyAudio
