BL^2/Re Value Doesn't Seem Right in FEMM - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 22nd August 2013, 06:09 AM   #1
Default BL^2/Re Value Doesn't Seem Right in FEMM
Hello,
I've been messing around in FEMM but the BL^2/Re value I'm getting seems to be too high. I was hoping someone who has a lot of experience with FEMM could verify if my figures seem correct.
Here are the specs for Subwoofer_C
Coil
OD: 82.55mm
WW: 65mm
Wire Diam: 19 AWG (0.912mm)
Re: 3.71 ohms (Dual 1.85 ohms in series)
BL: 34.49
BL^2/Re: 320.64
Magnet:
OD: 180mm
TH: 20mm
Top Plate:
OD: 180mm
TH: 10mm
Bottom Plate:
OD: 180mm
TH: 10mm/23mm
Pole Piece:
OD: 73mm
HT: 105mm
Here are the specs for Subwoofer_B
Coil
OD: 84.6mm
WW: 65mm
Wire Diam: 17 AWG (1.15mm)
Xmax: 27mm 70% BL
Re: 0.938 ohms (single 0.938 ohm)
BL: 14.1
BL^2/Re: 240
Magnet:
OD: 180mm
TH: 20mm
Top Plate:
OD: 180mm
TH: 10mm
Bottom Plate:
OD: 180mm
TH: 10mm/23mm
Pole Piece:
OD: 73mm
HT: 105mm
You can see the FEMM graphs in the attached photos. The motor is not that big but as you can see the BL^2/Re figure is quite large for both of them.
Old 25th August 2013, 08:25 PM   #2
Here's a pic of the specifications I have set for the 17 AWG Copper wire.
How to use FEMM? Spasticteapot Planars & Exotics 23 11th February 2011 05:44 PM
Femm ?? i dont get it what did i do wrong WrineX Planars & Exotics 14 17th September 2010 11:02 PM
Want To Buy 2SK146-BL 2SJ73-BL 2SK147-GR1 2SJ72-GR1 megasat16 Swap Meet 15 16th September 2010 02:37 AM
Adding Magnetic Properties In Femm ? valveitude Planars & Exotics 2 25th July 2005 04:41 PM
FEMM needed Peter M. Multi-Way 7 7th May 2005 04:46 AM
Copyright 1999-2017 diyAudio
