HELP: TINA model of oscillator using 4093 not working. Desperate!!! - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 17th June 2013, 08:38 PM   #1
Default HELP: TINA model of oscillator using 4093 not working. Desperate!!!
I'm trying to model a circuit that has a few 4093 NAND Schmitt triggers in it. I can't seem to figure out how to get the model working in TINA (Spice modeler from TI). I've seen the exact circuit modeled elsewhere on the web just fine, so I am really at my wits end here. I haven't modeled any logic circuits before now, so it could definitely be user error, but I am stumped.
PLEASE HELP!
Circuit and output are attached. It's right out of the datasheet! It should be a free running multivibrator but nothing is happening. I've included a timed switch so that pin 1 is pulled down to zero initially - that datasheet shows the transition low to high in case that was the source of the problem, but still nothing.
-Charlie
Old 17th June 2013, 09:01 PM   #2
Ahhhhrrggggh. OK, I figured it out. I was simulating the circuit using the condition "zero initial values", which seemed to me to be the case since the circuit is "off" prior to simulation. If I just changed this to "use initial conditions" the circuit simulates as expected. Oddly enough, I haven't actually included any initial conditions for the circuit! How great is that, huh.
Anyway, now that I have much less hair remaining on my head, this annoyance has been solved.
Old 2nd July 2013, 11:48 PM   #3
Yep, that cap needs to get charged to get the oscillator going.
Old 2nd July 2013, 11:57 PM   #4
No, the initial charge up wasn't the problem. No matter how long the sim time frame, there were no oscillations. As long as I used "zero initial values" it would not sim correctly. As soon as I switched to "use initial conditions" it worked as expected.
Use of a Ribidum Oscillator as refrence oscillator in a DAC Mark A. Gulbrandsen Digital Line Level 19 2nd November 2014 02:35 AM
6S4/6S4A TINA-TI/SPICE model? fhs Software Tools 10 10th May 2012 06:27 AM
Amp switching with 4093/4066. How to add indicator LEDs? soma_hero Tubes / Valves 3 20th January 2010 01:57 AM
I am desperate for help with my amp seafire Solid State 24 25th November 2009 03:42 AM
Copyright 1999-2017 diyAudio
