Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
LTSpice PSRR
LTSpice PSRR
Old 9th June 2013, 10:24 AM   #1
Neutrality is offline Neutrality  Denmark
Default LTSpice PSRR
How do you measure PSRR in LTSpice?
Been looking all over for any info on eaxctly how to do it, but have had no luck sofar.
I just want a simple explanation on how to do it on a amplifier simulation and maybe also an example.
Thanks.
Old 9th June 2013, 12:26 PM   #2
Mooly's Avatar
LTSpice PSRR
Good question. I would imagine the calculation is the usual 20log (v1/v2) where one of the voltages is the ripple on the rails.
Here's an LTspice file showing noise on the rails and the corresponding amplifier output. You can set your supplies up in a similar way.
This is what you should see on the amp output.
Old 9th June 2013, 12:46 PM   #3
jcx is online now jcx  United States
the .TRAN is always best - you can see nonlinear effects of bias cutting off, clipping
.AC analysis, adding the AC value to the existing DC Vsource lets you do a frequency plot - but like all .AC is only a linearized small signal evaluation around the operating point found at the start of the sim - no nonlinear effects will be seen
Old 9th June 2013, 01:02 PM   #4
Then how do you make LTSpice calculate 20Log(v1/v2).
Tried to add a new trace and enter the equation, no luck. Maybe I am doing it wrong.
Hmm.
Old 9th June 2013, 01:06 PM   #5
Mooly's Avatar
LTSpice PSRR
I wouldn't know how you would set LTspice up to calculate something like that... I'd just use a calculator
Old 9th June 2013, 01:22 PM   #6
.AC does display the Bode plot
for a .TRAN you can look at the waveforms in the FFT plot window, ratio the any signal's frequency component's magnitude, phase to the PS waveform's components with the cursors
Old 9th June 2013, 11:46 PM   #7
jazbo8 is offline jazbo8
jazbo8's Avatar
LTSpice PSRR
PSRR Example
You can also try right-click on the trace and enter the plot expression manually, e.g., 20*log(V(n001)/V(n002)).
LTSpice PSRRHide this!Advertise here!
topology and PSRR theChris Tubes / Valves 4 9th December 2016 05:20 PM
Opamp PSRR lumanauw Solid State 10 12th March 2007 12:42 PM
PSRR and Crosstalk dgardner Solid State 4 20th June 2005 01:09 PM
How to predict PSRR ? Kilentra Solid State 6 9th July 2004 07:31 PM
Designing for PSRR ALW Solid State 19 16th June 2004 07:00 PM
