Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Eagle PCB Design and rectangles/polygons
Old 2nd June 2013, 05:36 PM   #1
pyrohaz is offline pyrohaz  United Kingdom
Default Eagle PCB Design and rectangles/polygons
Hey guys,
I've designed a two layer PCB with the top layer consisting of rectangles and the bottom layer consisting of some electronic components (i'll include a picture so you can get the idea!), but I have recently realised that rectangles can't be linked to netlists (or if they can, I don't know how!), since i've got quite a few rectangles, could I find some form of script to convert all rectangles to polygons OR could someone possibly suggest a method to connect rectangles to nets?
Harris
Old 3rd June 2013, 02:35 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Rename each rectangle to the same as the net/signal that you want it to connect to (use the info-button in the schematic to find signal names) and then hit the ratsnest-button to refresh.
/U.
DIY projects blog
Old 3rd June 2013, 08:42 PM   #3
Hey Nisbeth,
Cheers for the reply.
Everytime I try and use the name tool, it just makes that stupid windows 'bing' sound, as if i'm not allowed to do it. Is there another way to name rectangles on Eagle?
Old 3rd June 2013, 08:59 PM   #4
Nisbeth's Avatar
Yes, before you draw them. Choose the tool, enter the name of the signal in the command line and press enter. Then draw and it should connect.
/U.
DIY projects blog
Old 3rd June 2013, 10:30 PM   #5
I can't seem to do it! Does it need to be done using the textbox at the top(ish) of the screen, sorry, i'm new to eagle!
Is there any way I can rename the pads i've already placed? I've got 80 perfectly aligned and don't really fancy doing them all again!
Eagle PCB Design and rectangles/polygonsHide this!Advertise here!
PCB Manufacturing Process with Eagle PCB Algar_emi Parts 1 3rd June 2016 10:48 PM
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 11 12th January 2014 09:01 PM
Suggestions on PCB: LM317 As Walwart Regulator (1st Eagle PCB) tommy_o Power Supplies 10 14th July 2011 03:05 PM
Eagle PCB design opinions (non-audio related) bmwpowere36m3 Software Tools 7 8th October 2010 03:24 AM
Need help with EAGLE PCB design software piro Multi-Way 1 14th April 2005 06:43 PM
