Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Need help installing LTSpice
Old 14th May 2013, 10:34 PM   #1
rif is offline rif  United States
Neither a cowbow nor dog owner
rif's Avatar
Default Need help installing LTSpice
When installing Spice (windows 7), I get this message. I don't really understand the implications, so I just hit OK. It installs fine, no errors.
Then sporadically when I run Run a Simulation the following may happen:
1) runs OK
2) LTSpice gives me an error that it can't open an empty file (something like that), then gives a half dozen other errors. Usually if I just Run the Simulation again, it works fine.
3) LTSpice says its waiting on a file and gives me a countdown from 10. It then runs fine.
4) Windows gives me some error and shuts down LTSpice.
If needed, I can get the exact errors. I've tried unistalling and reinstalling several times. I'm using the latest download from Linear (May 3rd version I think).
Thanks!
Old 14th May 2013, 10:50 PM   #2
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Try right clicking on the start menu and ruuning as administrator, if it works fine it is probably a permissions error. Windows7 has more restrictive permissions than earlier versions, and ltspice cant save to the program fles directory, and instead windows redirects stuff to your user profile,. this can get weird!
when installing you can override where it installs to. you could make a directory called c:\ltspice and try installing to there
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 14th May 2013, 10:56 PM   #3
jcx is offline jcx  United States
Vista has this "feature" too - before running any sim, save your schematic in a sim folder in "your doc" folder - have to navigate away from the default Ltspice install folder in "programs"
Old 15th May 2013, 01:42 AM   #4
dchisholm is offline dchisholm  United States
dchisholm's Avatar
There is also the "Security" tab in the program's "Properties" menu. I have been running LTSpice under Win7 without any problems - but if possible I install ALL of my applications in directories under " C:\Applications\ . . . " , rather than in " C:\Program Files\ " with all the junk that Microsoft installs. If nothing else, it makes them easier to find if I need to, for example, change a configuration file, uninstall the thing, etc.
Dale
Old 30th May 2013, 02:59 AM   #5
rif's Avatar
I haven't had a chance to use it much, but this seems to work ( now I just jinxed it).
I installed it into a folder I created on my desktop. I launch it by right clicking and running as administrator. that last part is critical.
now I need hands on time to get used to its somewhat unconventional UI.
thanks everyone for your help.
Need help installing LTSpiceHide this!Advertise here!
installing printer ? AndrewT Everything Else 38 13th September 2012 06:25 PM
installing RCA connection jasyip5052 Car Audio 5 16th January 2011 06:28 PM
installing sub without rca ibanez Car Audio 7 15th May 2007 12:58 PM
installing volume sarahlove Parts 6 16th May 2006 04:10 PM
Installing HornResp Relax Multi-Way 0 26th July 2005 11:17 PM
Copyright ©1999-2017 diyAudio
