Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Audio measurement using Arta under Linux
Old 4th April 2013, 11:17 PM   #1
gazzagazza is offline gazzagazza  New Zealand
Default Audio measurement using Arta under Linux
For those who might be using Linux I have just found I can run Arta under Wine and get great results. Essentially the same as under Windows XP on the same machine. I have an E-Mu tracker Pre and Ubuntu 12.10.
Pictures follow of it in action.
Old 4th April 2013, 11:23 PM   #2
Several THD plots in loopback mode.
File Type: jpg E-Mu Tracker Pre Loopback 100Hz Arta.jpg (96.3 KB, 311 views)
File Type: jpg E-Mu Tracker Pre Loopback 1kHz Arta.jpg (95.0 KB, 297 views)
File Type: jpg E-Mu Tracker Pre Loopback 10kHz Arta.jpg (95.9 KB, 282 views)
Old 4th April 2013, 11:25 PM   #3
A couple of IM tests in loopback
File Type: jpg E-Mu Tracker Pre Loopback 19k 20k IMD Arta.jpg (95.2 KB, 281 views)
File Type: jpg E-Mu Tracker Pre Loopback SMPTE IMD Arta.jpg (97.8 KB, 274 views)
Old 4th April 2013, 11:26 PM   #4
And an MLS derived frequency response.
File Type: jpg E-Mu Tracker Pre Loopback MLS Frequency Response Arta.jpg (104.8 KB, 76 views)
Old 4th April 2013, 11:37 PM   #5
Pano is offline Pano  United States
Pano's Avatar
Good to know, thanks!
No troubles of special tricks to make it work?
Old 5th April 2013, 12:59 AM   #6
It just installed, and worked! I followed Arta's instruction to go to Wine Setup and select the E-Mu as the audio device. That's all...
Old 18th September 2014, 12:02 AM   #7
Update. Emu Tracker Pre won't initialise under Ubuntu 14.04. Just lights up and stays lit up.
Audio measurement using Arta under LinuxHide this!Advertise here!
A note about ARTA audio analysis software richiem Software Tools 48 2nd June 2016 06:52 PM
ARTA - using ARTA to measure room acoustics! OMF Software Tools 0 25th November 2009 02:55 PM
ARTA tweeter measurement problems doug20 Multi-Way 9 22nd June 2009 01:38 PM
Anyone with a working ARTA measurement box ? zobsky Multi-Way 0 2nd July 2007 07:48 PM
ARTA Measurement Software hongrn Multi-Way 1 2nd July 2006 08:46 AM
