Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 31st March 2013, 01:49 PM   #1
Default Snubber Calculator
After reading Jim Hagerman's paper, "Calculating Optimum Snubbers" and working my way through the formulae several times, I figured it would be easier to put it all on a spreadsheet rather than getting the calculator out every time! I haven't been able to find anything suitable on the web so I put this together.
I've checked it with his figures and it looks accurate but perhaps someone with a more mathematical brain than me could confirm the accuracy. Also, I did the spreadsheet originally in Libre Office .ods format so the conversion to .xlsx is OK but isn't protected and the layout is slightly off. Not a major problem but feel free to tinker with it and format it properly for Windows.
Attached are links to the spreadsheets, the original article plus an alternative method of calculating resonant frequency.
Hope you find these useful and any constructive feedback is welcome.
http://dl.dropbox.com/u/109520947/SnubberCalc.ods
http://dl.dropbox.com/u/109520947/SnubberCalc.xlsx
http://www.hagtech.com/pdf/snubber.pdf
http://www.syscompdesign.com/AppNote...ar-pickups.pdf
Above calculators now updated to include drop down lists to enable data to be entered in different units. Also, .xls file added below for older versions of Excel.
Last edited by valve5425; 7th April 2013 at 07:41 PM. Reason: Revisons made and additional file added. April 7th 2013.
Old 31st March 2013, 03:21 PM   #2
xstreme is offline xstreme  Europe
xstreme's Avatar
So at first sight appears to be sufficient...
My Audio Freeware Apps : LINK
Old 31st March 2013, 06:09 PM   #3
Pano is offline Pano  United States
Pano's Avatar
Thanks very much for doing this! As xstreme says, it seems right at first glance. Will need to double check. Nice work on the spreadsheet and the formulas.
I was having fun modifying the XLS version to allow input directly in mH, pF and KHz, with the results in ohms, µF and pF for my own ease of use. All was going well until I tried to get the interwinding C to display in nF. Ooops, something went pair shaped. Will try again.
Take the Speaker Voltage Test!
Old 31st March 2013, 07:32 PM   #4
Glad it's of use. You should be able to enter values in scientific notation so 25nf would be 25e-08 Farads, 25pf would be 25e-011 Farads, etc.
Use something like this;
Electronics 2000 | Capacitance Unit Converter
Might make things easier and you could also cut and paste the result from the spreadsheet into the capacitance calculator.
Old 31st March 2013, 07:53 PM   #5
Just had a thought!! If I get the time I'll look at trying to incorporate a converter into the spreadsheet. Even better would be to make it possible to enter any value, but that would take a bit more working out.
Old 31st March 2013, 08:04 PM   #6
Pano's Avatar
It's not hard to do. I had it working well until I tried to fix the last cell. I'll post what I have, when I fix my mistake.
Old 31st March 2013, 08:18 PM   #7
Bill_P is online now Bill_P  United States
I believe there is an error in the Rs power calculation. The secondary RMS voltage term should be squared in the formula.
Old 31st March 2013, 08:19 PM   #8
Nice one! It's a bit late in the day here to be doing complicated stuff.
Old 31st March 2013, 08:21 PM   #9
Thanks for that. I'll check it out tomorrow.
Old 1st April 2013, 03:09 AM   #10
xstreme's Avatar
Originally Posted by valve5425 View Post
Glad it's of use. .
has nothing to do but it is interesting
eEngineer - Electrical Engineering, EMI/EMC, RFI
Snubber caps atmars Tubes / Valves 2 15th November 2008 01:10 PM
snubber p.s. wicho Chip Amps 11 21st October 2008 01:07 PM
Snubber pics? Dominick22 Chip Amps 20 7th May 2006 07:47 PM
Snubber AND non-snubber ? jimbo1968 Chip Amps 10 6th December 2005 07:49 AM
Snubber s2kov Tubes / Valves 13 30th November 2004 02:09 PM
Copyright ©1999-2013 diyAudio
