Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
iPad /iPhone frequency analysis software
Old 11th March 2013, 01:08 AM   #1
trondareo is offline trondareo  Norway
trondareo's Avatar
Default iPad /iPhone frequency analysis software
Surfing around the App store I found several offers for frequency analysers, FFT analysis with more pr less bling, also I noticed Parts Express have a suitable microphone. I am starting this thread to collect use experiences with this kind of software, for speaker analysis.
I have a very very olde pc I hve been using so far and need to update to something simple for my speaker design hobby.
Im doing stuff at http://taooftubes.wordpress.com/
Old 11th March 2013, 08:49 PM   #2
tvrgeek is offline tvrgeek  United States
As long as the ipad/ipod/iPhone or whatever can send sound out while it sends in, and the apps work. But: Just having a "spectrum analyzer" is useless.
To build speakers you need to do two measurements: Impedance vs frequency with phase and amplitude vs frequency with phase. Unless you have a chamber or a 30 foot pole in the backyard of a quite valley, you need gated ( MLS) measurements. An iPad has the horsepower I am sure.
Those two sets of measurements, in a semi-standard three column format, then input to the speaker modeling tools. The tools I use were compiled for a PC. I have no clue who has versions that tun on a tablet or phone. I can tell you the bigger the screen the better. For WinPSD, my 22 inch is too small. You are not going to do curve fitting on a 5 inch screen. I doubt on a 9 inch screen.
Old 12th March 2013, 09:44 AM   #3
trondareo's Avatar
I agree it has to support audio in and out simultaneously, also a big screen i desirable, so probably the full size ipad is the best option.
This microphone seems to offer audio I/O capability http://www.parts-express.com/pe/showdetl.cfm?partnumber=390-810
It would be great to hear if anybody has experiences with this.
Old 22nd March 2013, 05:21 AM   #4
lowpoke is offline lowpoke  Australia
I've just been playing with FFT on my iPhone. I watched a couple of their YouTube videos prior to purchasing and it looked pretty decent. Although I do have a measurement mic, I'm yet to purchase an XLR adapter so I can plug it into the phone. So I've just been using the inbuilt mic.
I'm not looking to use it for speaker analysis per se, but more to evaluate the system as a whole (and whether I need to consider room treatment). I've attached a response curve of my main system using pink noise. This was captured at the listening position.
From the little I understand on this topic, this seems to look OK (but I'm no expert). Are these peaks and troughs typical or should I be concerned?
Show us what ya got at Homebuilt Hi-fi
Old 28th March 2013, 09:10 PM   #5
Hint, you need room treatment. I can say that without seeing the room. Everybody needs room treatment. I don't mean over-priced ugly foam cutouts either.
You have not heard imaging until you have good front wall treatments.
You have a mic eh? Does it need phantom power? What about adjusting gain?
Old 28th March 2013, 09:24 PM   #6
To your specific question, everything below 125 is probably bogus. You did not say where this was measured. If it is at listening position, it looks pretty good. Maybe a bit bright. Pretty heavy smoothing. It is going to take a lot of experience to understand what a toy app like this is telling you. Measure many positions and write down what you think you hear in those positions then compare it all. Eventually you should get a fair understanding you can use. Remember, using pink noise you are measuring both the speaker and the room reverberation. It just does not tell you that much. Your ears do. A tool like this could be handy in the pocket if you hear something very wrong, it may narrow the hunt quickly.
Only worry about something you hear as wrong. Dips are hard to hear. I would be worried if the 7K peak is just the room, or if it was something bad like woofer breakup. Is the 2K peak just the room, or is it a phase problem with the tweeter? You don't have enough here to know.
Old 13th August 2014, 05:34 AM   #7
GringoAudio is offline GringoAudio  Canada
So is there an iPad app with gated measurements ?
Old 13th August 2014, 06:25 AM   #8
Is Impulse response recording as in the Audio Tools app (by Andrew Smith) the same as gated frequency analysis require to see how our DIY speakers are responding?
Old 24th August 2017, 12:49 PM   #9
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Default What is good analysis tool in 2017?
To revive a thread, what is a good ios-app for speaker checking?
- it must circumvent the high pass filter of the ipad/iphone;
- must allow me to use my own signal genrator (simple SPL I think)
- etc.
Just searching the app store brings too little results.
SPU --> tube MM/RIAA;
Pass buffer -->300B SE Anza Zaka; --> FE103 sigma TQWT
iPad /iPhone frequency analysis softwareHide this!Advertise here!
iPhone/iPad audio App: SPLnFFT: some free promotional codes Fabien Lefebvre Software Tools 4 25th July 2014 10:26 AM
An easy Soundlevel & Source Remote Control for iPad / iPhone JLOP PC Based 8 23rd February 2013 03:22 AM
DIY guitar to iPad/iPhone adapter knifeinthesink Instruments and Amps 0 14th October 2011 09:40 PM
Low frequency spectrum analysis, S.A. software, recommendations? Newbie here. emilimo701 Software Tools 5 24th May 2011 06:59 AM
