Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
HELP required
HELP required
Old 14th March 2013, 11:25 AM   #21
xstreme is offline xstreme  Europe
xstreme's Avatar
Originally Posted by tvrgeek View Post
THat requires the integrator and anti-aliasing filters.
Generation with adding a processing (see audio plugin) sometimes may resolve this aspect in digital world ?
My Audio Freeware Apps : LINK
Old 18th March 2013, 11:54 AM   #22
geraldfryjr is offline geraldfryjr  United States
Here is the link to the LatestREW, REWv5.01 Beta13.
I believe you have to be signed to Home Theater Shack to obtain it.
REW Version 5.01 Beta 13 Released - Home Theater Forum and Systems - HomeTheaterShack.com
Enjoy !!
jer
Old 18th March 2013, 03:29 PM   #23
dlr is offline dlr  United States
As Dave is progressing on WinPCD which may be easier to start on. Jeff's EXCEL version is a bit intimidating until you work your way through it a few times.
I've got a new version with some significant changes in the UI. The basics are the same, but there are improvements based on some user feedback that you may like. Let me know, I'll send you the latest.
Dave
Old 20th March 2013, 06:48 PM   #24
I was playing around with REWv5.01 Beta 10 and had forgot that it did impedance measurements as well.
So, I gave it a try and it too works most excellent!!
I tried it with various reference resistors ranging from 100 ohms to 10kohms and all of the results using my sample resistance of 10ohms and 51ohms were exactly the same no matter what the value range of the reference resistors were.
This was/is an issue while using the SimpleS software.
If the signal goes beyond the dynamic range of the sound card the REW software will give you a warning box that states as such.
This is a revelation as I was questioning the accuracy of SimpleS although it does quite well.
Comparing a test results to a previous test by SimpleS shows that SimpleS is fairly accurate but REW might a bit more by a degree even at a 48Khz sample rate.
I will have more on this later with a closer look at some fresh samples.
The main thing I like better about REW is that it only takes a fraction of the time to do a test as compared to SimpleS.
Cheers!!!
jer
Old 23rd March 2013, 12:30 AM   #25
I was trying out the new version of REW V5.01 Beta 13 last night.
I stumbled upon a new feature that I don't recall seeing before in the earlier Beta10 version that I have been using!!
It displays the values of inductance and capacitance along the curve when using the cross hair cursor.
It is displayed in a little box in the bottom left hand corner of the chart.
It also displays some resistance numbers as well and I am not sure but I but think that these are the actual winding resistances of the primary and secondary winding's of the transformer I was testing.
These numbers correspond to what I have measured before with my ohmmeter.
I am not 100% sure about this and I will look into this further.
If this is true, This is amazing data all measured from only the primary winding!!!
The inductance and capacitance values are also right on with this particular unit as compared to those I have measured with the other programs.
The repeatability of the curves using different reference resistor values is 100% !!!
I have used every thing from 50 ohm to 10k ohm for refference resistors and they all produce exactly the same curve as long as the signal is within its dynamic range of accuracy and shows no warning sign of such an error.
Here are a couple screen shots showing the two sets of important data I have found done with one measurement sweep.
Enjoy!!!
jer
HELP requiredHide this!Advertise here!
Help required xyz9915 Power Supplies 5 8th October 2008 02:35 PM
help required! ross1976 Analogue Source 0 15th December 2004 10:28 PM
Help required ! LarryN Parts 2 19th July 2004 01:05 AM
Help required martioz Swap Meet 3 2nd February 2003 03:42 AM
Help required please Andy G Multi-Way 0 29th November 2002 10:50 PM
