| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#11 |
OK, I got the results of HOLM to look the same as ARTA but with phase data. Conformation between tools is always nice. HOLM has lots of options but no explanation of what to pick. I am sure the programmer considered them obvious. I can see why people pick ARTA as a beginner. You get something right out of the box.
So, a cheapskate, not for commercial use tool set: Generate impedance and phase with LIMP, output as .zma Derive TSP from LIMP Generate SPL and Phase with HOLM. Output text as "custom, space delimited" and rename as .frd Import into PSD and you should be in business. |
#12 |
#13 |
Got it. Check your e-mail.
#14 |
#15 |
One evenings playing around. I did not need to RTFI once and got to a reasonable solution quite quickly.
Tiny bug I am sure you see, the box where you put in the NPE cap quality text is messed up. I brought in files from HOLM and LIMP with no problem. No edit, nothing. You need to have a smoothing toggle in the crossover pane. With real 1 meter measurements, it is really hard to see where the reference levels are. One third or even one octave smoothing helps with the general shape of things, but then going back to one twelfth or so is necessary to get any filters right. This needs to be in the crossover display pane, not the response editor. I think it would be more useful than if they were cleaned up before importing. I guess another way to do this would be to generate both raw and smoothed data sets. Import the smoothed ones first to get an idea of where you are going, then start over with the raw ones. Sometimes a procedure works as well as a feature. Second is the inability to adjust the target response which is at 0 dB, to the imported responses. I would like to be able to pick the average over some interval, likely the 500 to 1K range of the woofer, and adjust the target to that as zero. It would take quite a bit of spreadsheet work to do that before importing. (or a perl script.) I did the first guess at the BSC and notch filters in my spreadsheet, but a bit of a guessing game. A handy button would switch from the target to the applied perfect response so when fiddling with values, you have a reference to where you are going. That would help when you try and simplify to combine the BSC with the crossover. Again, having a smoothing function for display would help in tuning here too. Don't know how it picks the frequency range to start at 10. Wastes a lot of space that could be better used for crossover range resolution. 20 would seem to be a better default. Selectable best of all. Added in a little on the amp screen just for fun. Seems pretty complete. That's all for tonight. |
#16 | |||||||
![]() Quote:
Also, the larger program (PSD, not PSD_Lite) has a really nice BSC calculator that is comparable to the Edge program. I'll probably add the Baffle module to PSD_Lite on the next iteration and the response will show up as another line on the chart. Quote:
Plus, I need to understand the needs of other users that may be using the tools in different ways. I appreciate your time in writing this up and hope to get inputs from others.
#17 |
Glad to help. I encourage others to give it a try. Of course, the real test is I need to build what it recommended and then measure the results. Don't quite have enough parts in the box.
One advanced feature another high priced product does in the BSC is to allow adding edge radius. For all I know, it may just reduce ripple amplitude by some about per quarter inch or so. I will be interested to see your advanced version. If anyone is interested, the crossover that came out of about an hour playing with the curve fitting was a target of an LR4 at 2500 Hx. The actual results were a third order at 3200 and second order at 3500. Because I had them lying around, the drivers were the Zaph and a Vifa D27. Results are not far from what my experience. Off to order a couple of coils. suggests. It looks like I can do a step by step quick start guide pretty easy. Capturing all the defaults from HOLM and LIMP are taking some time. I need to find a link to a notch filter calculator. I used my own and that is no help to anyone. Pretty simple calculation though, pick a freq and a Q, then tweak to fit. Same kind of thing with a Zobel, though I find the calculated ones to not be as flat when I measure as I expect, so I tend to fit to the LIMP test. ( or WooferTester II) I am going through the same process with SE. It is not as quick that is for sure. Do-everything programs have that as a feature. Sometimes, you just need a hammer.
#18 |
OK, got HOLM to do 1/3 octave smoothing to export into PSD, so that solves that little bit. Talk about a no help guide, I am really going to do some work on that one.
#19 |
FRD input question
Bringing in an .frd file generated by HOLM. Data in HOLM looks good. Graph of phase in the preview does not. Any idea? |
#20 |
Imported data causing exception:
Axis Object auto interval error due to invalid point values or axis min/max The chart for the crossover amplitude is a box with a red X. I opened the files and pruned them to 20 -20K range. No help. If I open it up new with no driver files, it is fine. So, something funny importing my files. ( besides the off phase translation. ) Deleting everything and try again. |
| Interview w/famous speaker designer-covers common discussions | dantheman | Multi-Way | 86 | 25th July 2012 10:08 PM |
| Modelling driver pointed in multiple directions in passive crossover designer | Rijaak | Multi-Way | 9 | 23rd May 2012 08:19 AM |
| Help to understand this Inf. Beta One passive XO schematic please :) | TMHutson | Car Audio | 5 | 29th December 2010 12:57 AM |
| wanted: Coral Beta 8 or Beta 10 full range speaker | francofil | Swap Meet | 2 | 28th April 2010 08:34 AM |
| Looking for a speaker designer | RSTREAM | Multi-Way | 3 | 31st August 2009 08:14 PM |
