| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#21 |
I don't have the issue, whether in op or tran: it always shows the correct voltage of 7.33 something everywhere on the net.
It probably has to do with this: A simulation free zone. Design it, build it, test it. He somewhats knows you don't like him, so he doesn't like you. More seriously, this kind of things can happen for legitimate reasons: if you make a change after a sim, or if a change is pending before you start the sim, etc. Depending on the configuration, the fluke could be saved in the asc and be presented again as it is in some cases.
#22 |
![]() Maybe things like this happen in the turbulent weather zone where 'A simulation free zone.' (Design it, build it, test it.) and SPICE (the mother of all circuit simulators) collide... *scnr* Rundmaus EDIT: Elvee was seconds faster than me - damn!
#23 |
just another
Hi Elvee, were you just hovering (it shows the correct voltage if you do) or did you click and add a label? It is after clicking and adding the upper label that it goes wacky for me. after that voltages all over the circuit seem to go haywire.
Tony. |
#24 | |
Ideally, I think LTspice should gray-out these options as soon as something is changed. If you want to do that kind of thing, labelling the nodes of interest with non-standard names, like A, B, Out, In are the way to go. Otherwise, LTspice doesn't track the node names (and anyway, if you want to be general and complete, how would you do that, when you split a net for instance: which one inherits of the original title?)
#25 |
Does that mean that when you do a relabel and then rerun the sim that all is OK again?
jan
It is a capital mistake to theorise before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts - Sherlock Holmes Check out Linear Audio Vol 5! |
#26 | ||
![]() Quote:
![]() ----------------------------------------------------------------------------------------- I have done a fair bit of editing and did keep saving the file as it all progressed but it still seems a bizarre issue to me. I did flip the IC (to make it look neater) by chopping all the connections and then rotating it and connecting back up again. Might have a couple of ideas to try later...
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#27 |
Another circuit done weeks (months ?) ago. Its a similar circuit concept (yet totally different as you can see) and yet it exhibits the same error and node changing.
#28 |
just another
It seems that the placing of the "labels" that show the operating point at that place in the circuit is broken. But running the sim again fixes them and they show the right voltage. I would say it is a bug, but maybe it is "working as designed".
Tony. |
#29 |
I never tried that, running it again after tagging the lines. Your right, they do change to back to the correct data, both voltage and nodes.
#30 | |
combine this with what Elvee said: there's your "problem". |
| Phasing/soundtage anomaly | Puffin | Multi-Way | 10 | 25th November 2012 09:50 PM |
| Redplating anomaly? | dgta | Tubes / Valves | 18 | 29th October 2011 05:43 AM |
| JustMLS impedance anomaly | Mos Fetish | Multi-Way | 0 | 6th March 2007 01:00 AM |
| LL1660S Anomaly | arnoldc | Tubes / Valves | 17 | 3rd May 2006 01:00 AM |
| TAD TL-1102 response anomaly? | Alidore | Multi-Way | 0 | 27th January 2004 04:54 AM |
